Old 08-03-2008, 07:26 AM   #1
Default JR Tx Rx Questions
I have an old JR Racing XR2 Tx and a R125 Rx. It looks like the wire on the Rx has been cut. How can I verify how long the wire should be? Also, if I need to pick up a new Rx, what should I be looking for? The crystals in it right now are channel 5 - 27.195. If I need a new Rx, do I need to get one in the 27 range, or just anything that says AM on it?
Also, it says on the Tx "2 model memory". I'm assuming I would still need to change out the crystals, and it just remembers the setting for each one? Thanks for any light you can shed on the subject for me!
tekcor1 is offline   Reply With Quote
Old 08-03-2008, 09:07 AM   #2
nsane's Avatar
So I just gave my old XR3 a quick look and measure.. the stock antenae wire is 14 inches. You can probably swap out that wire with just a bit of soldering skills.
As for the memory, you're correct, or you can pick up a second receiver crystal on the same channel and not have to worry about swapping crystals at all.
Tekno e-D8 (build in progress)
Kyosho Lazer ZX5 SP
XXX-T CR
http://www.ncchampseries.com
nsane is offline   Reply With Quote
Old 08-03-2008, 02:19 PM   #3
Well Duh! That never even occured to me! But obviously I'll never be running both trucks at the same time, so it makes perfect sense. Thanks for pointing it out to me.
As for the receiver wire, I measured and it looks like it may not have been cut after all. It's 14" so maybe the end is just frayed. I guess I'll just put it in my car and do a range test. I appreciare all the help!
hyper7 shock questions and other questions buds302 Nitro Off-Road 1 06-11-2008 12:03 AM
B4: Kit vs RTR, Questions. BelialX13 Rookie Zone 15 02-14-2008 04:57 PM
kanai diff questions and other questions famous182 Electric Off-Road 2 02-25-2006 02:19 PM
TNX QUESTIONS chrometwanks Monster Trucks 2 02-03-2006 06:02 PM
TB questions nekmiyevo2 Electric On-Road 7 08-11-2005 09:37 AM
