Good LiPo for racing?
#31
The TrakPowers and Orions both have a smaller 2mm port in the middle that you use for balancing. Your shop should have an adapter or can get one to hook up to whatever balancer or balance charger you have.
A lipo charger and cc/cv are the same thing essentially. They charge at the chosen rate to 8.4 volts (4.2 per), then hold that with reducing current until completely full. Constant Current/Constant Voltage.
#32
I was looking at the Trakpower V Blancer and it looked like it goes into the positive and negative wires and it would go into the charger where u put the + and - things in.
#33
Yes, but the battery harness also has a connector for the balance port, and a smaller plug for the small balance port on the battery. Then just 2 wires between charger and the balancer.
http://www.trakpower.com/index.asp?p...s/products.asp
Well ya need to click on the V balancer page, then cell balancing, it will show you.
#34
So are you just saying the I plug the wires into the battery and plug the other wires into the charger and it will balance?
#35
Yes as far as the wiring, I think you need to push a button on the balance unit before charging to get the balance charge. Check the V balancer manual. I have a balance charger in one unit, just plug it in and charge. Not completely sure about the double unit deal.
#36
Also you dont need a lipo balancer. IVe ran and charged my lipo over 20 times and there still completely balanced. My hobby shop said its really not needed. The cut off also doesn't need to be purchased just make sure you dont run the battery low. You can tell when it falls off. Just pull off the track and get it back on the charger. It will be twice as long as any nimh anyways!
#39
orion and track power in my opinion are the 2 top packs you can buy. i use orion 4800 in my sp just cause it has a slightly thinner,shorter profile than tack power and i need that in the kyosho. the 3200 saddle pack from track power seems to be gaining popularity real fast with the d4 and b44 crowd.
#41
So would the Trakpower 4900 fit in the xxx-t battery tray?
#42
Chris, as I understand it the 100/200 cycle thing is worst case, hard discharge all the way to 6v, with a very strict definition of performance drop off. If you only use 80% of the capacity the cycle life goes up quite a bit with any lipo. In any event I'm fairly sure its better than any nimh.
With a good lipo balancing doesn't seem necessary for a while, but I think it will catch up with us eventually. High discharges is one of the things that raises the risk.
Brand wise I think TrakPowers are most excellent. Orions are good too, and they have new better ones coming out.
#43
Was your second line a typo? I've been racing an early double x buggy for fun, for that I have to use an Orion 3600 to get it to lay flat. None of them really fit in my vintage JRx stuff.
#44
I meant xxx-t on the 2nd line. So good that everything will fit good. Does it come with connectors where u plug in? Does it use bullet connectors or what? Can I have a link?
#45
what i do is wire from the speed control to the battery with 4mm bullet connectors. no need for deans connector this way and a good solder job will not break.
