Old 08-01-2008, 11:02 PM   #1
Questions?? Rustler drive shaft problem
My drive shaft has been poping off my rustler were it goes into the gear box and has been ever seince i locked the difs and it pops of every time i drive it and its a pain in the a$$
smokey7567 is offline   Reply With Quote
Old 08-02-2008, 10:19 AM   #2
RC Dad's Avatar
Trader Rating: 26 (100%+)
Send a message via MSN to RC Dad
My guess is that you're running on pavement? When turning, physics dictate that the outer wheel must travel farther than the inner wheel. Since you locked your diff it's now forcing both axles to turn at the same rate. The axle is popping out because something has to give and it's now the weak point.
You may find that the inner bearing on your outer hub is bad, and is allowing the axle to push outward far enough to pop free but if not you may need to free up the diff to allow turning.
GV2 Pro, XXX4G+, Blitz SCT, CRC GenXL
RC Dad is offline   Reply With Quote
Old 08-02-2008, 12:40 PM   #3
Miller_Time's Avatar
Trader Rating: 11 (92%+)
Any particular reason that you locked your diffs? I doubt you'll be able to solve that if you keep it locked, as said above there has to be something that will give. The Traxxas drive shafts are very strong, I use them on both of my crawlers where they get a ton of torque working through binding wheels. Once you pop one the plastic part is probably stretched or even broken so you'll need to replace that part most likely.
Miller_Time is offline   Reply With Quote
Old 08-02-2008, 12:44 PM   #4
Turbo Joe's Avatar
Trader Rating: 41 (100%+)
Sure you're not just missing the grub screw? You had to take it out to lock the diff...it goes through the outdrive and it holds the outdrive to the diff. If it's there, there's no way for the axle to come off. It's a little post with threads and it's maybe a half inch long or so at the most.
I had a Rustler with a locked diff and I never had a problem...and we beat the hell out of it with a 7-cell battery and a brushless motor.
Turbo Joe is offline   Reply With Quote
Old 08-02-2008, 01:57 PM   #5
big greg's Avatar
Trader Rating: 119 (99%+)
i would have to ask also why you locked the diff, ive had my vxl for a year now and the diff works great even on loose dirt, also never had a driveshaft prob
big greg is offline   Reply With Quote
Belt Drive vs shaft drive vic88my Nitro On-Road 16 11-10-2007 08:26 AM
Belt Drive versus Shaft Drive SUNA Nitro On-Road 20 03-28-2006 09:04 PM
Belt drive versus shaft drive...pros and cons of each? AttackDonut Rookie Zone 21 01-02-2005 05:23 PM
Belt drive or Shaft Drive tc3wood Electric On-Road 4 12-03-2004 07:57 AM
Shaft Drive or Belt Drive? dino.tw Nitro On-Road 109 05-25-2004 11:04 PM
