Old 01-02-2009, 02:59 PM   #121
Originally Posted by C Reedy View Post
2wdMod i did what you said and now when i turn my right rear wheel my left rear wheel spins the same way instead of the opposite way... same for the front. is this right? and could it just be because i am running brushless and there is less resistance?
When the car isnt on that is what will happen. Think of the diff balls spinning.
Losi 8ight 1.5 ~ 8T ~ XXX Buggy ~ Mini-Baja
The o''le saying goes, pay me now, or pay me later, because you gonna pay me. "Pearl_414"
Chris__RC is offline   Reply With Quote
Old 01-02-2009, 03:06 PM   #122
C Reedy's Avatar
Okay cool and thanks
C Reedy is offline   Reply With Quote
Old 01-02-2009, 03:29 PM   #123
ddesros2's Avatar
When running your RC, racing or bashing....
NEVER LET GO OF THE WHEEL!!
I've seen it too many times, someone "blipping" the wheel to turn. This causes the car to become unstable due to it returning to center every time. You will keep sucking if you keep doing this.
ddesros2 is offline   Reply With Quote
Old 01-02-2009, 08:53 PM   #124
Klen420's Avatar
My secret:
Before you even enter the track, sit in your car, and let the buddah sooth ya
Losi XXX-CR Xcelorin 17.5
Klen420 is offline   Reply With Quote
Old 01-04-2009, 05:00 PM   #125
Suspended
When driving in a race only focus on your own car, try not to watch the other cars and only worry about what you are doing..
B4 Racer1 is offline   Reply With Quote
Old 01-15-2009, 01:58 PM   #126
Suspended
Make sure that your car has all the screws tight and that the car goes perfectly straight or it will affect the way your car drives drastically...
Old 01-15-2009, 02:20 PM   #127
jamminnay's Avatar
Send a message via AIM to jamminnay Send a message via MSN to jamminnay
practice, practice, and more practice!
jamminnay is offline   Reply With Quote
Old 01-15-2009, 03:58 PM   #128
Suspended
Come on guys post away...
Old 01-15-2009, 04:33 PM   #129
Registered User
UltegraSTI's Avatar
Trader Rating: 20 (100%+)
all else fails, call tommy vu
R
UltegraSTI is offline   Reply With Quote
Old 01-15-2009, 05:01 PM   #130
LIVipers's Avatar
Trader Rating: 41 (100%+)
Hey Bryan you forgot one part.....make sure you car HAS all the screws. I have had so many races end early because of random parts falling off due to lost or missing screws.
LIVipers is offline   Reply With Quote
Old 01-15-2009, 05:25 PM   #131
Chimer's Avatar
Trader Rating: 26 (100%+)
Default Check front tires
I accidentally put 2wd front tires on my 4wd. Be sure to put the correct tires on the correct wheels. The 4wd tires are slightly wider than the 2wd-this is for front tires only. I did not notice I was running the wrong tires until someone at the track pointed it out to me.
Chimer is offline   Reply With Quote
Old 01-15-2009, 05:35 PM   #132
Rebuilding the shocks have got to be the number one cure for my ill handling R/C. (A/E & Losi in particular)
I replace the o-rings (and plastic pieces in AE if possible) in my shocks nearly every race day. The o-rings seem to swell and don't allow the shaft to slide smoothly. O-rings are not very expensive. I buy them bulk from a guy that advertises on hobbytalk & R/C Extreme (maybe here too).
If you don't believe me, next time you rebuild your shocks, test it for yourself. Empty the oil out of your front (or rear) shocks. Replace the o-rings in one of the shocks, and slide the shaft in & out a few times to seat the parts. Now compare how smoothly the shock shaft slides through the rebuilt shock compared to the 'un-rebuilt' shock before adding oil again. It is quite noticeable.
groundhogg is offline   Reply With Quote
Old 01-15-2009, 05:41 PM   #133
jamminnay's Avatar
that kind of takes away the front grip!
Old 02-02-2009, 12:40 PM   #134
Suspended
make sure that your servo saver is tight...
Old 02-02-2009, 12:45 PM   #135
SQC049's Avatar
Trader Rating: 16 (100%+)
Make sure you don't have front truck shocks on the rear of your B4. Also, makes sure you have the right shock shafts in the front of your 4 wheel.
Andrew Parente
| Serpent America | Picco | AKA | LRP America | Desoto Racing | PT Racing Oils | TQ Wire |
SQC049 is offline   Reply With Quote
Speed Secrets (SS) RedEnzo Malaysian R/C Racers 197 09-21-2013 06:23 AM
Off-Road Tuning Secrets haulin79 Electric Off-Road 13 06-27-2008 09:30 PM
speed secrets?! any thoughts? streetracer745 Electric Off-Road 21 05-29-2007 11:51 AM
Racing Secrets!! Steve Charles Electric On-Road 68 11-22-2003 09:47 AM
