Old 08-03-2008, 07:54 PM   #61
Suspended
Originally Posted by scott54 View Post
There's some really good advice on this thread. Good idea.
I have a couple...
- If you find yourself tearing your diff case apart at a track, spray your car down with a light mist of WD40 to keep the dust in it's place and not falling into where it's not supposed to be.
- Don't listen to the guy always giving you advice, listen to the guy that keeps beating you. There's always someone at the track that THINKS they know everything but can very well be completely wrong.
That was very well put..
B4 Racer1 is offline   Reply With Quote
Old 08-03-2008, 07:55 PM   #62
Suspended
what should i do if my cvd keeps poping out on my 4 wheel...
Old 08-03-2008, 09:01 PM   #63
Suspended
And also the front wheel nut keeps coming off...
Old 08-03-2008, 10:27 PM   #64
JeromeK99's Avatar
If your front "left" wheel keeps coming off... change the nut! The nylon insert doesnt last forever...
If your front cvd is popping out of the outdrive you are probably getting too much shock travel... maybe change mounting position...
Jerome
JeromeK99 is offline   Reply With Quote
Old 08-03-2008, 10:29 PM   #65
Brandon A's Avatar
find a better locknut dude
RCAmerica/Xray <> Panther <> RW Mods
Brandon A is offline   Reply With Quote
Old 08-04-2008, 03:20 PM   #66
Chimer's Avatar
Trader Rating: 26 (100%+)
Replace the small plastic washers used as spacers to adjust the wheelbase. I noticed they get worn out over time and the suspension becomes sloppy.(this was on my B4 and T4)
Check out your CVD/axles and outdrives for wear. If you don't replace them your driveline will be very sloppy.
Don't use harsh chemicals such as motor spray or nitro blast to wash out the inside of your shock bodies-it will eat the o-rings that seal the shock shaft.
Put your epoxy, glue, shock oil, etc. in a plastic bag or tub and then put it in your toolbox. This way your tools won't be glued together or be too slippery when you get to the track.
Read the instructions thoroughly!!!!!!!
Do not over tighten screws!
If your tools are worn out to the point they don't work properly replace them.
Put a dab of Diff Lube on the threads of the turnbuckles before you screw on the ball end-this will make your adjustments easier.
Chimer is offline   Reply With Quote
Old 08-04-2008, 06:59 PM   #67
Suspended
try using the nut to hold it on
move over is offline   Reply With Quote
Old 08-04-2008, 07:08 PM   #68
Trader Rating: 16 (94%+)
wow rocket-mtrsprts... just because you got suspended doesnt mean you should make another account
BSS07 is offline   Reply With Quote
Old 08-04-2008, 07:10 PM   #69
Suspended
thanks for the tip i didint know you were supposed to do that maybe ill try that...
Old 08-04-2008, 08:49 PM   #70
superdave2's Avatar
well i see know one mentionn the packing up to go to the track go the night before the race and pack up all your parts and boxes and everything you think your gonna need at the track and if there is any second guessing that (should i take this) TAKE IT im sure you just might need it or you can help out someone else and then at the end of the day make sure you have all your stuff and get all the tools you have lent out and leave a clean pit spot and dont leave garbage or any other stuff there just throw it away and you should be good on that
Team Terribles~ARCS Hobbies~Have Fun Hobbies~Answer-RC~Torco Fuel~Fastlane Graphix~ Caster Racing Products~Maxamps~Clockwork Racing Engines~BCG Industries
losi 8t dps .28 jr z9100s jr z9000t
spektrum dx3
superdave2 is offline   Reply With Quote
Old 08-05-2008, 06:45 PM   #71
Suspended
if your cvd pins keep falling out try putting some thread lock in the set screw and tighten it as hard as you can..
Old 08-05-2008, 07:01 PM   #72
dan r's Avatar
i can't delete this..
dan r is offline   Reply With Quote
Old 08-07-2008, 11:03 AM   #73
What helped me the most was: I would go to my local track early and throw a mild mod motor in and practice with it. This will make you a lot faster in stock. It will teach you some throttle control. If your fast in mod, you'll be fast in stock.
KYOSHO/ORION/NOVAK/Team Dialed/Intermountain R/C Raceway/ WWW.ir-cr.com
Kobe Yonker is offline   Reply With Quote
Old 08-07-2008, 11:06 AM   #74
Wheelnuts are always gonna wear out if your switching tires a lot. I change mine every 2 weeks just to be certain, that my race isnt gonna be over because of mechanical error.
Old 08-07-2008, 11:26 AM   #75
Im gonna try that. I just ordered a Checkpoint 19t, Orion Element 19t, and a Peak 13X5 and a 12X5 armature and extra brushes and springs for $50.
Losi 8ight 1.5 ~ 8T ~ XXX Buggy ~ Mini-Baja
The o''le saying goes, pay me now, or pay me later, because you gonna pay me. "Pearl_414"
Chris__RC is offline   Reply With Quote
Speed Secrets (SS) RedEnzo Malaysian R/C Racers 197 09-21-2013 06:23 AM
Off-Road Tuning Secrets haulin79 Electric Off-Road 13 06-27-2008 09:30 PM
speed secrets?! any thoughts? streetracer745 Electric Off-Road 21 05-29-2007 11:51 AM
Racing Secrets!! Steve Charles Electric On-Road 68 11-22-2003 09:47 AM
