Old 08-03-2008, 08:20 AM   #46
Originally Posted by oxymoron View Post
that's what I did, but we did testing years ago and found that any lanoin-based shampoo works better as it doesn't contain a degreaser like simplegreen does, which dries out the natural oils in the rubber, while just cleaning them returns the sought after like-new tacky feeling
+1
Also it doesn't eat at the foam inserts the way simple green does.
"It's like his brain is running a 64p spur and 48p pinion, sometimes it will engage and work but mostly it just makes a terrible noise"
Stallard is offline   Reply With Quote
Old 08-03-2008, 12:42 PM   #47
macr0w's Avatar
I'm sure everyone will agree that the biggest secret in the R/C world is: How much money we spend on this stuff.
www.clearspotrecording.com
macr0w is offline   Reply With Quote
Old 08-03-2008, 12:47 PM   #48
Regional Moderator
CarbonJoe's Avatar
At least when spouses are involved!
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 08-03-2008, 12:53 PM   #49
Briguy's Avatar
Trader Rating: 125 (100%+)
Send a message via Yahoo to Briguy
Originally Posted by Stallard View Post
+1
I`ve been using simple green for near 20 years and never had a foam problem because of it . Don`t let your foams get soaked and they last a lot longer .
At Your Service Vinyl Works
Royal R/C & Hobby
Leisure Hours Hobby & Raceway
Briguy is offline   Reply With Quote
Old 08-03-2008, 02:10 PM   #50
JeromeK99's Avatar
I'd suggest not "soaking" or dunking your tires.. The little tub with a brush glued upside down works quite well.. Like the earlier poster said, just fill it up until you get to the top of the bristles. Then just rotate your tires to use the bristles to scrub off the dirt. If you soak or dunk tires, the foams will soak up the water/liquid like a sponge. This will give you severely unbalanced loppy tires! It will take sometime for the foams to dry and yes they will probably shrink or start to come apart if they got wet.
I used to race on a track for many years with "Step-Pins" and a fluffy watered track. Loved it! When I would race gas, I would also have my pit guy have a wire brush to quickly knock off some of the caked on mud on my tires after the warmup laps during the gas topoff if it was too muddy. This allowed me to have a traction and stearing advantage off the line. Everybody else also had caked up tires until a few jumps where they could "goose" the throttle to try to get some of it off.
Jerome
JeromeK99 is offline   Reply With Quote
Old 08-03-2008, 03:35 PM   #51
Suspended
Originally Posted by Chris__RC View Post
How do you clean the tires?
i use a tub with simple green i find this easiest to do and it works really well..
B4 Racer1 is offline   Reply With Quote
Old 08-03-2008, 05:26 PM   #52
UN4RACING's Avatar
Trader Rating: 22 (100%+)
I'm taking that one to my grave.
UN4RACING is offline   Reply With Quote
Old 08-03-2008, 05:52 PM   #53
Here is the problem me and other at a local track found with simple green a long time ago.
Our track runs pink taper pins, from full tread to bald depending on track conditions so a set of tires lasts forever.
When I was using simple green about every 6 months my foams (Losi firms)would breakdown, when I pulled the tire apart the foam would be turning to dust.
When I stopped using simple green the problem went away. have tires that are 5 years old, with original foams that I still race with.
Others had the same problems and stopping the simple green stop the foam breakdown.
Also we never dunk the tires or get the foams wet.
Old 08-03-2008, 06:38 PM   #54
Briguy's Avatar
The track I go to run the same tires except most use Bomb one foams . Now , if you don`t dunk the tires or get the foams wet , then how can you blame your foam issues on simple green ? Like you said the foams don`t get wet , which simple green can`t be the problem if you don`t get the foams wet . Racers been using simple green before I got into the hobby and that was back in the 80`s . In 1/8 tires we have holes in them and so when cleaning them they tend to get a little wet and doesn`t harm those either .
Royal R/C & Hobby
Old 08-03-2008, 06:45 PM   #55
Suspended
What do u mean by dunking the tire...
I have never heard of that...
Old 08-03-2008, 06:52 PM   #56
Briguy's Avatar
It`s pretty self explanatory .
You never seen someone dunk their tires in their tire tub while cleaning or to rinse it off ?
Always see someone do that once and a while .
Royal R/C & Hobby
Old 08-03-2008, 06:54 PM   #57
Suspended
oh i have done that before...
Old 08-03-2008, 07:04 PM   #58
dr_hfuhuhurr's Avatar
Trader Rating: 75 (100%+)
Put live squirrels in the other racers pit bags. Make sure they are good and hungry (or better yet, rabid). They will be so busy (the racers and the squirrels) that they won't have time to get ready and you'll win by default.
Alternatively, you can get sharks with freaking lazers on their heads...
If that doesn't work, keep your equipment clean always. I tear my cars almost completely down after racing every week.
"There is a fine line between hobby and mental illness. Which side are you on?"
“Life is hard; it's harder if you're stupid.” - John Wayne
dr_hfuhuhurr is offline   Reply With Quote
Old 08-03-2008, 07:40 PM   #59
Originally Posted by 2MUCHSTUFF View Post
Before a race, turn each nipple 1/4 turn counter-clockwise - it really gets the blood flowing!
This sounds like something learned at the Gayte in Cleveland...
Counter-clockwise is only for onroad. You have to turn them clockwise for offroad. Nitro racers...well you don't want to know what they have to do to be fast
Old 08-03-2008, 07:52 PM   #60
scott54's Avatar
There's some really good advice on this thread. Good idea.
I have a couple...
- If you find yourself tearing your diff case apart at a track, spray your car down with a light mist of WD40 to keep the dust in it's place and not falling into where it's not supposed to be.
- Don't listen to the guy always giving you advice, listen to the guy that keeps beating you. There's always someone at the track that THINKS they know everything but can very well be completely wrong.
TLR Racing - ARCS Speedway - B-Fast Racing - Dialed RC - G-Force
scott54 is offline   Reply With Quote
Speed Secrets (SS) RedEnzo Malaysian R/C Racers 197 09-21-2013 06:23 AM
Off-Road Tuning Secrets haulin79 Electric Off-Road 13 06-27-2008 09:30 PM
speed secrets?! any thoughts? streetracer745 Electric Off-Road 21 05-29-2007 11:51 AM
Racing Secrets!! Steve Charles Electric On-Road 68 11-22-2003 09:47 AM
