Old 07-29-2008, 08:21 PM   #1
cla5675's Avatar
Trader Rating: 49 (100%+)
Default Type of velcro for buggy bodies?
What type of velcro are you guys using to attach buggy bodies to the chassis? I'm sick of losing body pins!! I saw some 3M stuff with an adhesive backing. Is the adhesive strong enough to stay on the chassis and body? Any info is greatly appreciated!!
cla5675 is offline   Reply With Quote
Old 07-29-2008, 08:39 PM   #2
jla8874's Avatar
Trader Rating: 23 (100%+)
The best I've found is at Lowe's. Its called Industrial Strength I believe and its Velcro brand. Its about $7 for 8 feet which is pretty cheap. And both the adhesive and the Velcro itself are plenty strong enough for r/c use. The Velcro will hold heavy lipo's securely to a chassis. The key is to work the two sides back and forth in to one another and then they form a bond that it is VERY hard to release.
jla8874 is offline   Reply With Quote
Old 07-29-2008, 08:56 PM   #3
Briguy's Avatar
Trader Rating: 125 (100%+)
Send a message via Yahoo to Briguy
I use either the Velcro or 3M brands and they seem to hold up pretty good .
At Your Service Vinyl Works
Royal R/C & Hobby
Leisure Hours Hobby & Raceway
Briguy is offline   Reply With Quote
Old 07-30-2008, 12:03 AM   #4
JeromeK99's Avatar
I've used the Velcro brand available at Walmart (in their craft section) and sometimes at the 99cent Stores... If you crash hard enough to break it loose.. there might be other things to concern yourself with first!
Good luck!
Jerome
JeromeK99 is offline   Reply With Quote
Old 07-30-2008, 06:53 AM   #5
cla5675's Avatar
Thanks for the info guys!! I'll hit Lowe's while I'm out running errands tonight.
Old 07-30-2008, 07:26 AM   #6
abailey21's Avatar
Trader Rating: 36 (100%+)
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 07-30-2008, 07:51 AM   #7
Suspended
For the most part the ordinary 3M stuff you noted is likely good enough. Then again if you're running an 1/8 buggy, with it's heavier platform, or do a lot of wrecking (no offense) then you might check into some heavier-duty stuff that holds a lot firmer as it's intended for more industrial uses.
But do not under any circumstances use it to hold down battery packs - it's not worth the risk. People have been trying to use sticky back velcro in RC uses since it came out back in the 80s, including the industrial grade heavy duty stuff, and all it's resulted in is people ruining their electronics or batteries or whatever when it gets ejected from the vehicles after a hard crash and costing them money.
Hold on bodies = good
Hold on anything else = bad
rocket-mtrsprts is offline   Reply With Quote
Tire Warmers - velcro wrap around gillottine Australia Wanted to Buy 0 08-12-2008 10:25 PM
Hot Bodies Cyclone or Losi JRXS Type R. Which one for 17.5 Brushless? FREAKAH Electric On-Road 9 06-09-2008 05:34 PM
WTB: 3 Racing Velcro Battery Strap cpatel529 R/C Items: Wanted to Buy 0 04-24-2008 07:41 PM
can i use velcro? AE Basher Electric Off-Road 9 07-15-2004 10:30 PM
Velcro or Double sided tape? lawndoggie Electric On-Road 36 01-19-2004 03:06 AM
