Old 07-27-2008, 07:17 PM   #1
hallj290's Avatar
Trader Rating: 2 (75%+)
Questions?? xxx-t mf2
does any one know of a company that make steel tranny gears for the xxx-t mf2?
Team Losi Racing
Parkersburg Rc Speedway
"Let's Do It In The Dirt"
http://www.freewebs.com/hallj290
hallj290 is offline   Reply With Quote
Old 07-27-2008, 08:53 PM   #2
kstarr's Avatar
no one that im aware of. whats going on with it i run losi for the last eight years.
byb.racing
speedysracingparts.com
banzaimotors.com
kstarr is offline   Reply With Quote
Old 07-27-2008, 09:01 PM   #3
hallj290's Avatar
Unhappy xxx-t mf2
i just got mamba 7700 and ran 3 battereys through it and stripped the idler gear and diff
Team Losi Racing
Old 07-27-2008, 10:30 PM   #4
superdave2's Avatar
WOW just from the motor you might want to check the bearing i stripped the diff gear because i blew out a out drive bearing but i have never heard of any steel gears
Team Terribles~ARCS Hobbies~Have Fun Hobbies~Answer-RC~Torco Fuel~Fastlane Graphix~ Caster Racing Products~Maxamps~Clockwork Racing Engines~BCG Industries
losi 8t dps .28 jr z9100s jr z9000t
spektrum dx3
superdave2 is offline   Reply With Quote
Old 07-27-2008, 10:46 PM   #5
hallj290's Avatar
Default mf2
the bearings are crisp and not siezed or any thing just wanted to know the answer to the first question
Team Losi Racing
Old 07-28-2008, 02:29 PM   #6
JeromeK99's Avatar
I don't believe anybody makes metal gear sets for the GenII Losi tranny. Honestly you shouldn't be stripping gears out even with that motor.
The tranny cases DO wear out and so does the aluminum top shaft. If any of the gears are worn, you WILL strip out gears.. the first to go is almost always the idler gear. Also make sure to put some grease on the aluminum top shaft.. just a little.. this will save the idler gear.. otherwise it will grind down especially with a hot mod.
Jerome
JeromeK99 is offline   Reply With Quote
Old 07-28-2008, 03:12 PM   #7
Briguy's Avatar
Trader Rating: 125 (100%+)
Send a message via Yahoo to Briguy
Whenever going to brushless you should be doing you maintenance on the tranny more frequently then normal .
At Your Service Vinyl Works
Royal R/C & Hobby
Leisure Hours Hobby & Raceway
Briguy is offline   Reply With Quote
