Old 12-30-2008, 06:40 AM   #76
Regional Moderator
CarbonJoe's Avatar
Originally Posted by jph View Post
What is the best temperature to solder batteries?
The hotter, the better, since it will melt the solder in the shortest time. The idea being that you want to melt the solder and heat the battery bar / wire, but not the cell. Ideally, you'd like to apply the heat for 2 - 3 seconds and that's it. Use a battery making jig like the Deans or Venom one to hold the battery bars in place.
A quick primer:
1) Scuff or lightly sand the cell ends
2) Clean the cell ends with motor spray
3) Place cells in battery jig in correct orientation
4) Pre-tin the cell ends
5) Allow cells to cool
6) Use jig hold battery bar(s) in place
7) Apply heat and possibly more solder so that bar "sinks" in puddle of melted solder (one end of battery bar at a time, no more than 3 seconds each)
8) Allow cells to cool
9) Flip jig over and do the other side
10) Allow cells to cool
11) Apply a small amount of Shoe Goo between cells to help hold them together if desired
MuchMore makes a neat jig to help solder tabs on to the cells to solder your wires to, and pre-bent battery bars for the tabs.
http://www.muchmoreusa.com/battery-accys/mmrc2170.jpg
http://www.muchmoreusa.com/battery-accys/mmrc2138.jpg
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 12-30-2008, 10:14 AM   #77
bradfox2's Avatar
To the OP
take the tips off that bernzomatic torch and just use the flame.
I use it to remove bullets and do other misc soldering work. Tin the cell and bar and then hold the flame tip to the bar for like 3-4 sec and you should be good.
That way you dont have to buy anything else.
the 40 watt weller is pretty much the standard otherwise.
bradfox2 is offline   Reply With Quote
Old 12-30-2008, 05:40 PM   #78
jamminnay's Avatar
Send a message via AIM to jamminnay Send a message via MSN to jamminnay
i have had a weller for a lonnng time.. My hakko is way better of course but it is way more expensive.. i think a good soldering iron is a must for any rc racer
jamminnay is offline   Reply With Quote
Old 12-30-2008, 06:05 PM   #79
Regional Moderator
CarbonJoe's Avatar
The Hakko 936 is available direct for $79.97, with the "skin" of your choice. Had to beat that deal. It comes with two chisel tips as well. Buy good tools once, and you'll have them for life. This thing heats up in literally 30 seconds.
http://www.hakkousa.com/products_rc.asp
Old 12-30-2008, 06:34 PM   #80
jamminnay's Avatar
+1 hakko´s rule!
[/I]QUOTE=CarbonJoe;5227976]The Hakko 936 is available direct for $79.97, with the "skin" of your choice. Had to beat that deal. It comes with two chisel tips as well. Buy good tools once, and you'll have them for life. This thing heats up in literally 30 seconds.
http://www.hakkousa.com/products_rc.asp[/QUOTE]
Old 12-31-2008, 07:00 PM   #81
jph
A quick primer:
Ok, thanks.
I will do this at work, we have a Pace MBT there.
jph is offline   Reply With Quote
Solder / Solder Stand - Available Online? RC12 Electric On-Road 7 05-01-2008 10:20 AM
What Solder! BuggyKing Chat Lounge 20 10-28-2007 01:37 PM
Solder Help Please tonyking73 Electric Off-Road 11 09-17-2007 03:42 AM
What solder Mossie Australian Racing 1 12-08-2004 05:03 PM
solder gun kh15 Electric On-Road 5 07-21-2004 06:37 AM
