Old 07-31-2008, 02:14 PM   #61
kdeselms's Avatar
Yeah I saw that one, it's a little more expensive - I don't mind using a dial.
The other nice thing about the Hakko iron is, it's ready to go in under a minute. I turn it on and thirty seconds later, it's ready to start soldering. Every other cheap iron I've ever had (way back in high school) took several minutes to heat up and they lost their heat in a hurry, and you had to let them build it back up.
I can't speak to the Weller's quality, obviously it has its proponents here that have success with it. I just know I saw a whole lot of the Hakko irons at the Shootout and it's what they use in the shop there at Hot Rod's, so I bought one figuring there was a reason for it...and there definitely is.
Kevin Deselms
Associated Factory Team SC10
Webmaster, www.hotrodhobbies.com
kdeselms is offline   Reply With Quote
Old 07-31-2008, 03:38 PM   #62
Send a message via AIM to CE28N
my weller is doing fine as it is. All i recommend is a stand with a built in sponge or wire cleaner if you get the iron by itself. I see ones as cheap as 7 dollars and as expensive as 80 out there. For me, it really doesn't matter if my iron heats up in 2 or 3 min compared to 30sec. Don't get me wrong however. The hakko looks really nice and the quick heatup is a nice luxury to have, but its not a necessity for me. As long as it heats up, stays at that temp and does the job, i really don't care what iron is used..
Last edited by CE28N; 07-31-2008 at 03:45 PM. Reason: found out there were very expensive stands out there. = /
CE28N is offline   Reply With Quote
Old 07-31-2008, 04:05 PM   #63
Suspended
+1
rocket-mtrsprts is offline   Reply With Quote
Old 07-31-2008, 04:14 PM   #64
Suspended
what it really comes down to is your preference as you can see of what iron to get pretty much as long as your happy with it..
B4 Racer1 is offline   Reply With Quote
Old 07-31-2008, 10:07 PM   #65
Trader Rating: 95 (99%+)
Here is what I use both for hobby and work. Heats up in about 20 seconds and works great. A new one includes a spare heating element and tips are very reasonably priced.
It's a hakko without the hakko name on it.
http://www.circuitspecialists.com/prod.itml/icOid/7307
www.rcrcr.com --------> B-Mag free since fall '07
RobbieS is offline   Reply With Quote
Old 07-31-2008, 10:09 PM   #66
Yeah!!!
+ the free voltmeter rocks!!!
"It's like his brain is running a 64p spur and 48p pinion, sometimes it will engage and work but mostly it just makes a terrible noise"
Stallard is offline   Reply With Quote
Old 08-01-2008, 06:33 AM   #67
Me likey. How do the tips hold up?
cjtamu is offline   Reply With Quote
Old 08-01-2008, 07:08 AM   #68
The one I use for hobby has their 4mm tip in it. In the winter I always direct soldered my batts into the cars as well as taking motors in and out so it has seen quite a bit of use. I have been on the original tip and ceramic element for serveral years now and it is still in excellent condition.
The key to keeping them in good shape is turning them off when not in use. That's the nice thing about a good iron that heats up fast.
Old 08-01-2008, 08:44 AM   #69
Suspended
Check me if I'm wrong, but I don't think the cool-down time for any iron has anything to do with how quick it heats up.
Old 08-01-2008, 08:51 AM   #70
That's why I'm looking at this one. I hate leaving an iron on all day, it eats up tips and there are always people walking by and looking at the cars, bumping into tables, etc. Love to have one that heats in 30 secs.
Old 08-01-2008, 08:55 AM   #71
Wow!!
Did you even read the posts?
Cjtamu was asking how the tips hold up, Robbie answered that turning off the iron also helps prolong tip life.
If you turn your iron off untill you need it then having one that heats up quickly helps.
Who said anything about cool down time?
Old 08-01-2008, 09:03 AM   #72
Suspended
Originally Posted by Stallard View Post
Wow!!
I knew there was a reason I had you on IGNORE.
Funny, but I think unplugging an iron accomplishes the same task as turning one off. Then again, for those that can't handle the unplugging bit I'd guess the turning off will be a problem as well.
Did YOU even read the posts?
Old 08-01-2008, 09:10 AM   #73
Regional Moderator
CarbonJoe's Avatar
People would be less likely to turn off or unplug their iron if it takes 5 minutes to come back up to temperature.
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
Old 08-01-2008, 09:43 AM   #74
Suspended
I've had a few different irons over the years, and seen many others in operation, and I've yet to see one that took 5 minutes to come up to temp.
Old 12-29-2008, 10:01 PM   #75
jph
What is the best temperature to solder batteries?
jph is offline   Reply With Quote
Solder / Solder Stand - Available Online? RC12 Electric On-Road 7 05-01-2008 10:20 AM
What Solder! BuggyKing Chat Lounge 20 10-28-2007 01:37 PM
Solder Help Please tonyking73 Electric Off-Road 11 09-17-2007 03:42 AM
What solder Mossie Australian Racing 1 12-08-2004 05:03 PM
solder gun kh15 Electric On-Road 5 07-21-2004 06:37 AM
