Old 07-26-2008, 07:57 PM   #1
LOSI SCOTT's Avatar
Trader Rating: 70 (99%+)
Default GTB question?
Ok i run spektrum and use the dx3r remote. Can you run the GTB non spektrum with the spektrum stuff? If anyone knows let me know. Thanks
LOSI SCOTT is offline   Reply With Quote
Old 07-26-2008, 08:00 PM   #2
Tubaboy's Avatar
Yes u can
www.wyomingrc.com | www.wyomingmodelerspark.com
Tubaboy is offline   Reply With Quote
Old 07-26-2008, 08:01 PM   #3
LOSI SCOTT's Avatar
Ok why have 2 quit in the past week that are non spektrum and my spektrum has no problems????????
Old 07-26-2008, 11:06 PM   #4
Super Moderator
Don't know why you are having problems, but Spektrum is unlikely to be the issue. A regular GTB with Spektrum is a very common combination, have one myself. For a while with a DX3.0, and now with a DX3R.
Any other info concerning the failures?
There is an issue on the GTBs with wiggling the steering servo while the battery is connected. Which I experienced the first day. Now I always unhook the battery right away. There is a fix, they can put a diode in the receiver power wire.
Dave H is offline   Reply With Quote
Old 07-27-2008, 08:40 PM   #5
Tubaboy's Avatar
Also, what exactly is quitting? The speedo or the receiver? Do you still have steering? Is this in 4 cell or 6 cell applications? Are you using lipo batteries?
More info please!
Paul
Old 07-27-2008, 09:54 PM   #6
Regional Moderator
CarbonJoe's Avatar
Yes, you can use the regular GTB with Spektrum radios. The Spread Spectrum optimized version switches the FETs at a higher frequency that would interfere with standard radios, so you shouldn't go the other way (use a SS GTB with regular radios). Check the switch harness connector and wires. I had intermittent operation that turned out to be a broken wire in the the harness.
*** The Gate - Celebrating 8 years at the same location ***
The difference between genius and stupidity is that genius has its limits. - Albert Einstein
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car
CarbonJoe is offline   Reply With Quote
engine question and radio question alucard13 Nitro On-Road 12 09-12-2008 09:21 AM
Bolink TF drag car question and BL question parnelli97 Electric On-Road 2 08-20-2007 06:32 AM
This is gonna sound stupid question but I have a battery Question. Smoke21 Electric On-Road 7 04-25-2004 09:10 PM
indi charger question/3300mhz battery question TT_Vert Electric Off-Road 4 12-27-2003 12:46 PM
Nitro engine question - newbie question. BloodClod Singapore R/C Racers 6 09-11-2002 10:33 AM
