Old 07-21-2008, 12:05 PM   #16
GravityJunkie's Avatar
And make sure you balance it as it charges. I've accidentally put lipo under the rated min. One cell were fine, one was a little lower and one was really low. I got all cells back, but I had to balance as I charged. Without balancing, that's a very easy way to overcharge a cell.
GravityJunkie is offline   Reply With Quote
Old 07-21-2008, 01:08 PM   #17
Trader Rating: 16 (94%+)
im charging the other one as we speak..... it went from 5.9 to 6.4 volts in 2 minutes.....its been charging for over 10 min. right now soo far soo good
BSS07 is offline   Reply With Quote
Old 07-21-2008, 01:11 PM   #18
SQC049's Avatar
Trader Rating: 16 (100%+)
You should be watching it, not posting on the internet! Make sure you have a fire extinguisher handy.
Andrew Parente
| Serpent America | Picco | AKA | LRP America | Desoto Racing | PT Racing Oils | TQ Wire |
SQC049 is offline   Reply With Quote
Old 07-21-2008, 01:13 PM   #19
lol im out here with my laptop on my porch watching the thing
Old 07-21-2008, 01:16 PM   #20
im soo confused with lipo.......
if i charged it up to its full charge.....run it for like half a pack....then put it back on the charger, why does it still charge up to a full charge? i would think it would charge up to about half. where is all the Mah going to?
Old 07-21-2008, 01:17 PM   #21
SQC049's Avatar
It shouldn't. If it is a 4800 and you do one run on it, it should only take about 1100mah or so.
Andrew Parente
Old 07-21-2008, 01:22 PM   #22
im talking about the trinity 4500's. when i ran it the last time i only probaly ran it for 10 min. when i put it on the charger it charged to the full 4500 but when the voltage level becomes 8.4, there's a beep but its not the finish melody
Old 07-21-2008, 01:27 PM   #23
kdeselms's Avatar
I noticed that with LiPo chargers (or multi-battery chargers with a LiPo setting, like my Orion Advantage) they go full amps up to a certain point, and then the amps they deliver starts to gradually drop as the battery gets closer to capacity, until it's just trickling in. I imagine it's like filling a water jug - you open the water tap all the way till it gets closer to the top, and then you start to gradually slow down the water supply until it's full. I also have an add-on balancer with my LiPo battery to make sure the cells are getting equal amounts of juice.
In reading online, LiPo just requires a lot more care and attention than other battery types...I sure would never buy one used, knowing what I know about their volatility. I even keep mine stored inside the LiPo sack, just in case
Kevin Deselms
Associated Factory Team SC10
Webmaster, www.hotrodhobbies.com
kdeselms is offline   Reply With Quote
Old 07-21-2008, 01:29 PM   #24
*UPDATE* its up to 3387mah and 7.404 volts
Old 07-21-2008, 01:30 PM   #25
yeah thats the last time im buying something used
Old 07-21-2008, 01:38 PM   #26
SQC049's Avatar
Keep an eye on it. The one at LIR on Thursday didn't pop until it was all but done.
Andrew Parente
Old 07-21-2008, 01:42 PM   #27
no one looked at the charger so we didnt know
Old 07-21-2008, 01:43 PM   #28
Jason Pelletier's Avatar
Trader Rating: 33 (100%+)
Sorry, I was worried about my face getting burned......
Island Raceway & Hobby
Jason Pelletier is offline   Reply With Quote
Old 07-21-2008, 01:49 PM   #29
dont worry about it...... i think the other one is good....
4736 mah
7.980volts
Old 07-21-2008, 01:52 PM   #30
k this pack is fine
but something weird happened...... at the end of the charge the voltage shot up to 8.7volts
NIP Novak 5amp lipo regulator with volt monitor, NIP venom 1600mah lipo rx pack sharkman R/C Items: For Sale/Trade 1 06-10-2008 02:36 PM
LIPO CHARGER LIKE HYPERION AND LIPO BATTS AND MAYBE CHEAP 12TH SCALE jslider R/C Items: Wanted to Buy 1 02-16-2008 07:55 AM
FS TrakPower 7.4V 4900MAH Hardshell Lipo,TrakPowerBalancer,TrinityReference 4500 Lipo ffpm46 R/C Items: For Sale/Trade 11 01-29-2008 06:11 PM
Pg 2 on Complete Sellout Motor rebuild Orion Lipo, peak Lipo 4800 and more gunlocators R/C Items: For Sale/Trade 18 10-08-2007 02:11 PM
Battery Recovery (Help) Calvin Ng Electric On-Road 4 07-28-2003 07:00 AM
