Old 07-22-2008, 09:21 AM   #16
KostaG's Avatar
Trader Rating: 48 (100%+)
Any of you guys running a oneway diff in a B44?
Current Cars:
- Schumacher SX3 & Cougar SV
- Mugen MRX5 WC, Serpent 966e (4s)& Motonica P81e (6s)
Collector/Vintage Cars:
-Serpent F180 (2x), Serpent Veteq, Losi Jrx2, Tamiya Avante & Associated RC10
KostaG is offline   Reply With Quote
Old 07-24-2008, 12:54 AM   #17
Lots of people run spools in on-road. I even have on in my 18r.
As far as running a one-way in a b44, i dont believe many people are, but i could be wrong. It seemed like one-ways in a 4wd buggy is a thing of the past, i know im taking mine out (xxx-4). it seems like you just cant drive aggressive enough, maybe if you were on a long fast track you could possibly have an advantage. my 2 cents.
Tater salad the stories behind nick names how it stuck at that track is beyond me, good times, short lived, forever missed FHR.
Tater salad is offline   Reply With Quote
Old 07-24-2008, 06:54 AM   #18
sport10's Avatar
One ways make a 4wd more aggressive not less. They add alot more offpower steering and change the braking to rear wheel only so you get better pivot in the corners. This really helps on tight tracks with alot of 180 degree corners. Plus the spool like lockup gives better onpower steering verses a diff. Putting a diff in its place makes the car more forgiving and easier to drive but slower. I have done compairsons and I an usually about .5 seconds a lap faster with a oneway generally. The only time I swap in a diff is when the track is rough and has alot of big jumps. Most people that run at the tracks I run at in 4wd buggy use oneways. I just takes a different driving style than a diff does to take full advantage of a oneway. Oneway diffs are not going anywhere anytime soon.
Hot Bodies VE8 w/ RX8-1900 combo
Associated B44
Associated B6
Associated TC7.1
Durango DESC410V2 Pro
sport10 is offline   Reply With Quote
Old 07-24-2008, 12:35 PM   #19
If braking were done by 4 wheel disc brakes like on a real car, would there be any advantage to running oneways everywhere i.e. (front and rear)?
haulin79 is offline   Reply With Quote
Old 07-24-2008, 01:21 PM   #20
Buckyaga's Avatar
I am a huge fan of one-ways, but it seems with the B44 its different in that department. All the setups from the pro drivers run with a tight front diff. I have not tried a one-way in my B44, but I have so much steering as it is, I don't think it would do much more.
Also, with a one-way in the front, you do get more pull out of the corners, but you also will have a lot of on-power oversteer coming out of the corner as well.
Buckyaga is offline   Reply With Quote
Old 07-24-2008, 04:08 PM   #21
sport10's Avatar
That is why they are faster but harder to drive. They tend to make a buggy twichy too. But I like my buggies setup which alot of steering. I too have driven the B44 and it does have decent steering with just a front diff but falls a little short of my x-5 with a oneway in the steering department. My x-5 also has a good amount of steering using a front diff too.
Associated B44
Associated B6
Associated TC7.1
Old 07-24-2008, 07:56 PM   #22
Not sure if your definition of agressive is the same as mine but i cant enter the corner as fast without having all 4 tires doing the braking, and because im still running a one-way in the front of my xxx-4 i tend to get hacked because i brake for the corner a little sooner and if i brake later then i get hacked by the person trying to get under me because i was forced to go a little wider. I do race on a tight track that has alot of flat corners, the track surface is clay if that makes a difference. I do plan on putting my diff back in the front and testing it out but im with ya, i have allways been a fan of the one-ways in the front, it just fits my driving style better.
Old 07-24-2008, 08:00 PM   #23
Well you wouldnt really get the advantages of the one-way up front unless you had the brake biased more for the rear. On accelaration they will act like a spool but just not as reliable as a regular spool.
Also with all 4 corners having bracking independently from each other this may affect the operation of the diff. while bracking and steering.
Old 07-24-2008, 10:32 PM   #24
sport10's Avatar
The more steering a buggy has the more aggressive it can be driven. Oneways add a ton of steering off power and also allow you to do rear only braking. This way you can really throw around the rear in a corner. And with the spool like lockup on accelleration you can really power out of a corner. With the increased off power steering you can really cut under other drivers to make the pass. This is what I mean by more aggressive. I try to cut corners as tight as possible to avoid being hacked and it also helps to be defensive against drivers that try and cut under you. On 180 style corners brake late and just enough to allow the rear to pivot the 180 degree corner and power out hard is the fastest way I have found to take these type corners with a 4wd.
Associated B44
Associated B6
Associated TC7.1
Old 07-24-2008, 11:27 PM   #25
I get what youre saying now, i guess im so used to driving 2wheel stock sportsman buggie that i still havent adapted to the 4wheel mod driving style.
Old 07-25-2008, 12:41 AM   #26
Buckyaga's Avatar
you are all forgetting the best reason to run a one-way
1. go hot into a corner
2. punt the car in front of you off the track
3. politely say on the driver stand "sorry, running a one-way"
4. victory!
Fioroni Front/Rear Diff for Ofna/Gs Imdadundada7 R/C Items: For Sale/Trade 30 03-14-2007 07:39 PM
HPI Pro 4 Front One Way and rear diff. Blacktiger355 R/C Items: Wanted to Buy 4 03-06-2007 08:09 AM
Front & Rear Diff fluid changes, how it affects steering? Cain Monster Trucks 11 08-01-2006 02:34 PM
front/rear kyosho diff needed quickly maxxman101 R/C Items: Wanted to Buy 0 06-02-2005 11:02 PM
MTX3 FRONT and/or REAR Diff. rcfoolz R/C Items: Wanted to Buy 1 06-30-2004 12:13 AM
