Old 07-20-2008, 09:18 AM   #16
jla8874's Avatar
Trader Rating: 23 (100%+)
It refers to the way the cells are wired, in series or parallel. I found this on internet:
A battery is a group of cells.
A cell has a capacity, measured in Amp*Hours (pronounced "Amp Hours" ), abbreviated as "Ah".
A cell has a certain amount of potential to do work, measured in Volts, abbreviated as "V".
When you put cells in series, their voltage is added together. For example:
-----> [- 3.7V +] [- 3.7V +] [- 3.7V +] ----->
This battery has 3 cells in series, so this is called a "3S" battery. The total voltage of this battery is 3*3.7V = 11.1V.
When you put cells in parallel, their capacity is added together. For example:
.--> [- 1.2Ah +] --.
---|--> [- 1.2Ah +] --|--->
'--> [- 1.2Ah +] --'
This battery has 3 cells in parallel, so this is called a "3P" battery. The total capacitance of this battery is 3*1.2Ah = 3.6Ah.
You can use combinations of cells in series and in parallel to achieve different levels of Voltage and Capacitance. For example:
.--> [- 1.2Ah, 3.7V +] [- 1.2Ah, 3.7V +] [- 1.2Ah, 3.7V +] [- 1.2Ah, 3.7V +]--.
---|--> [- 1.2Ah, 3.7V +] [- 1.2Ah, 3.7V +] [- 1.2Ah, 3.7V +] [- 1.2Ah, 3.7V +]--|--->
'--> [- 1.2Ah, 3.7V +] [- 1.2Ah, 3.7V +] [- 1.2Ah, 3.7V +] [- 1.2Ah, 3.7V +]--'
This battery has 3 parallel groups of 4 cells in series, so this would be called a "4S3P" battery.
The total voltage of this battery is 4*3.7V = 14.8V, and the capacitance of the battery is 3*1.2Ah = 3.6Ah
jla8874 is offline   Reply With Quote
Old 07-21-2008, 05:42 PM   #17
I have nothing but good things to say about Trackpower and there customer support is second to none. One of my 4900's was feeling a little weak and they shipped me a new one and also let me keep the old one! I will buy only Trackpower lipo's.
JLinney is offline   Reply With Quote
Old 07-21-2008, 08:43 PM   #18
i have 6 of 4900 trakpower packs and just got a 5400 trakpower and love them.
sght4 is offline   Reply With Quote
Old 07-21-2008, 08:46 PM   #19
jla8874's Avatar
You do know the 5400's are only 16C right?
Old 07-22-2008, 07:22 PM   #20
i dont think thats a big deal when you look at the big picture, a good NiMH pack has a max discharge rate of 35A, the 4900 lipo is 96A and the 5400 is 86.4A
Old 07-22-2008, 10:33 PM   #21
rcjunkie3000's Avatar
Trader Rating: 94 (100%+)
Originally Posted by D.Lasoski20 View Post
i have a novak gtb with a 6.5 and im looking to get a lipo pack, do i need a lipo cut off for this esc or not,
And also would an orion 4800 platinum be a good lipo pack
thanks
I also read that you can contact Novak and give them the serial number of the speed control and they can determine if it has the cutoff circuitry or not. I have a GTB that I'm not sure has Lipo cutoff circuitry so I'll contact them also.
RCJunkie3000 - Gonzo69 Paints / Lex Tyler Paints / Norcal Hobbies
http://www.rctech.net/forum/r-c-items-sale-trade/344416-rcjunkie3000s-garage-sale-batteries-escs-chargers-cars-accessories-etc.html
rcjunkie3000 is offline   Reply With Quote
Old 07-22-2008, 11:30 PM   #22
Francis M.'s Avatar
thanks
Go ahead and buy the lipo. They have a very flat discharge curve and just stop as soon as you see a noticable loss in power..... I've been using my orion 3200s and orion 3600s and the power loss is noticable when the voltage gets under 7.0 volts....
I run touring 10.5 with thee 3600 orions and my voltage is always around 7.5 after 5 minutes.....
My suggestion would be to get something close to 5000 capacity since I know off road guys tend to run more than 5 minutes at a time.....
TQ-racing Yokomo BD7 Airtronics
Francis M. is offline   Reply With Quote
Old 07-23-2008, 02:44 PM   #23
I just got off the phone with Novak @ 949-833-8873 and the customer service person was very helpful and friendly.
Regarding Lipo Cutoff, the GTB has a barcode and below it is the serial number beginning with a "J" followed by 5 numerics. It is located underneath the ESC so it has to be out of your car.
If the serial number begins with:
J22xxx or above it is the GTB with Lipo Cutoff Circuitry
J12xxx, J20xxx or any number below J22xxx, then it does NOT have Lipo Cutoff Circuitry.
Hope this tidbit helps
NIP Novak 5amp lipo regulator with volt monitor, NIP venom 1600mah lipo rx pack sharkman R/C Items: For Sale/Trade 1 06-10-2008 02:36 PM
LIPO CHARGER LIKE HYPERION AND LIPO BATTS AND MAYBE CHEAP 12TH SCALE jslider R/C Items: Wanted to Buy 1 02-16-2008 07:55 AM
FS TrakPower 7.4V 4900MAH Hardshell Lipo,TrakPowerBalancer,TrinityReference 4500 Lipo ffpm46 R/C Items: For Sale/Trade 11 01-29-2008 06:11 PM
Pg 2 on Complete Sellout Motor rebuild Orion Lipo, peak Lipo 4800 and more gunlocators R/C Items: For Sale/Trade 18 10-08-2007 02:11 PM
Lipo charger with power supply and 2 cell lipo pack fweemindan R/C Items: For Sale/Trade 3 01-03-2007 11:51 PM
