Old 08-23-2003, 11:54 AM   #1
Default Need Radio Help ASAP Pleaseeeee.
I have both an old Futaba Radio and a brand new POS from towwer hobbies. When I ran the car last year before engine died I had no probs with radio. Now I have installed new radio and engine evry thing runs fine untill I get more than 10 feet away then I lose all control of the truck.
I have changed recievers and get the same prob. I have not changed out trans yet because my Futaba's battery holder is FUBARED. Please help. I have also tried differebt crystals.
LosiGTX is offline   Reply With Quote
Old 08-23-2003, 02:07 PM   #2
Hey check your transmitter battery power, and make sure the transmitter's antenna is screwed in all the way.
Vortex Buggy is offline   Reply With Quote
Old 08-23-2003, 02:18 PM   #3
Thumbs down Hey Vortex
Just checked battery voltage at transmitter = 12.5 good there, took apart transmitter and checked antenna good connection. I fixed my futaba transmitter and both are doing same thing on two sets of crystals. re-routed the reciever antenna well away from servo wires and still have the problem.
Think maybe for some reason I need more than 6 volts to the reciever, never had more than 6 before?
Old 08-25-2003, 11:12 AM   #4
Hmmm...
Well, I know for a fact the receiver doesn't need more than 6V, the battery box (for non BEC receivers) had 4 batteries in it. Maybe your BEC Circuitry is slightly damaged? Try 'eliminating' the Battery Eliminator Circuitry as a test. Who knows?
Seems like a longshot, but maybe something has moved into your area that is creating a lot of interference. Try some other radio control device and see if that performs similarly.
Old 08-25-2003, 03:05 PM   #5
Default Thanx
Still no help other R/C's are working fine. Guess I will have to visit the dreaded hobby shop this weekend. Thanx again
Old 08-26-2003, 01:35 PM   #6
Default Hey Vortex
There is something i have not tried yet but was reading an article on radio's. I checked and I had my crystals backwards tx in the rx and vise versa, I will try this later and see if it makes a difference.
Old 08-26-2003, 02:15 PM   #7
Send a message via AIM to uDi_MP7.5
uDi_MP7.5 is offline   Reply With Quote
Old 08-26-2003, 03:44 PM   #8
Default UDI
You need to get a 4 AA battery pack and plug it straight into the reciever. Thats all very simple, will not be any better than the BEC except that your battery will last a little longer than usual.
Old 08-26-2003, 03:46 PM   #9
Default Vortex.
No luck on the crystal switch, Did not help at all. Guess next time I will buy a better radio than the tower hobbies brand If I could just find the antenna to my Futaba I think I would be ok.
Old 08-26-2003, 10:27 PM   #10
If u have a three channel receiver you can plug the batt pack to the third channel(bypassing the bec) and it will give max volts/amps to the servos
eltorito is offline   Reply With Quote
WTB: Synthesized/Non-Synthesized Radio for Mini T ASAP!! smarking1212 R/C Items: Wanted to Buy 7 07-14-2008 12:34 PM
*ASAP* NEED REAR HUBs FOR 1/12 THATS 3 BOLT *ASAP* we R/C Items: Wanted to Buy 1 10-06-2007 10:50 PM
NEED RADIO TX BATTERY ASAP amain R/C Items: For Sale/Trade 0 08-29-2006 07:55 PM
tq2/tq3 radio needed asap hurley081182 R/C Items: Wanted to Buy 2 02-02-2006 08:10 PM
Need asap: .12 engine, servo's, receiver, radio Speedy1 R/C Items: Wanted to Buy 8 05-05-2004 07:16 PM
