Old 07-13-2008, 04:38 AM   #1
Default electric problems with t4.
I have an associated t4 with a novak GTB and 13.5 brushless. I run trak power 4900 lipo, and some times it will just stop. I'll have steering but no go. I've checked my solder connections, the little white plug on the esc, it doesent feel hot when it happens either. I'll leave it set awhile then it's fine again. any suggestions.
mduncan31 is offline   Reply With Quote
Old 07-13-2008, 05:37 AM   #2
the fos's Avatar
hey, next time it happens wriggle the sencer wire and see if that helps, if that dont work have a look at the conection plug that go's into the reveiver to see if thats dodgey, if any of those an't the problem well i dont have a idea in the world.
the fos is offline   Reply With Quote
Old 07-13-2008, 06:22 AM   #3
Drifting101's Avatar
i have been having the same probles with mine but only when i gun it
::Mi4::17.5::::::M03R::HW 3000kv::::::T4::7.5::::::HB Cyclone D4::5.5::
"Why follow, when you can lead?"
Schumacher
Drifting101 is offline   Reply With Quote
Old 07-13-2008, 09:41 AM   #4
Tech Legend
Cain's Avatar
Trader Rating: 240 (100%+)
If possible, try a different battery and see if it still occurs.
Also, try the battery you have in another brushless equipped vehicle and see how it performs.
< Tekno EB48SL / SCT410.3 | Tekno EB410 x 2 | Yokomo YZ-2 DTM x 2 | LC Racing EMB-1 Buggies and Truggies >
Old 07-13-2008, 02:40 PM   #5
killer89's Avatar
Trader Rating: 41 (100%+)
Send a message via AIM to killer89
check the esc lights to see if its going into thermal shutdown mode.
killer89 is offline   Reply With Quote
Old 07-13-2008, 03:02 PM   #6
Trader Rating: 16 (94%+)
lipo-cutoff hahha... did u set it up for lipo cutoff mode though?
also when does it stop? like how many minutes can you drive it for without this happening?
BSS07 is offline   Reply With Quote
Old 07-13-2008, 04:06 PM   #7
Suspended
it could be a false charge on your battery or like bSSo7 said lipo cut off
B4 Racer1 is offline   Reply With Quote
Old 07-13-2008, 08:14 PM   #8
My old GTB was doing this also. I couldnt get it out of Lipo cut-off mode
it's like it froze there. Guys are the track couldnt even figure it out.
They said it was my sensor wire coming loose. They even shoo gooed it
in the slot and everything....no give... I figured my motor might have went out on me,
so I sent in my old stuff to novak and got a replacement GTB and motor.
Have not had a problem out of the new one so far.
Seems like this guy had that same problem I did.
electricguy007 is offline   Reply With Quote
4wd Electric Buggies, Electric M18, and Axial Crawler. gt3angel R/C Items: For Sale/Trade 17 10-31-2008 09:04 PM
electric problems littlewhitefw05 Australian Racing 12 08-04-2008 06:36 AM
Simple site restructuring...Problems with Electric Onroad section. Soviet R/C Tech Site Forum 18 05-04-2005 12:39 AM
Electric Motor Problems LosiFromHell986 Electric Off-Road 7 01-29-2004 01:16 PM
GM V12 XC Problems AN Electric On-Road 2 01-26-2004 12:19 AM
