Old 07-11-2008, 02:40 AM   #1
tom_chang79's Avatar
Default FlightPower - Trackpower Saddle Pack Voltage?
What is the voltage of the individual packs? Are they 7.4V/2 = 3.7V?
tom_chang79 is offline   Reply With Quote
Old 07-11-2008, 02:56 AM   #2
UK.hardcore's Avatar
1 piece of a Trakpower saddle is 3.7 Volt nominal.
the 2 in series then becomes 7.4V.
A racecar is only as good as the mechanic who build it.
UK.hardcore is offline   Reply With Quote
Old 07-11-2008, 02:59 AM   #3
Thanks UK, that's what I figured since this pack is hooked up in series.
I'm considering to buy this for my BJ4WE and for use on my Robot, which uses Hitec HSR5990TG servos. I'm trying to keep the voltage down, below the rated 7.2V.
Do you know of any LiPos that comes in 6.0V nominal? Equivalent to a 5-cell sub-C NiMH? All I see is 7.4V LiPos and 11V LiPos...
Old 07-11-2008, 03:21 AM   #4
Registered User
5 cell sub-c will peak at over 6.0v but what you could use is a regulator...
Loop&Roll is offline   Reply With Quote
Old 07-11-2008, 05:32 AM   #5
jla8874's Avatar
Trader Rating: 23 (100%+)
Thats 7.4 nominal. After a full charge they will be 8.4. So if you're real worried about your electronics you can go one of two routes, either way poke your head in over at the 1/8 scale electric conversion thread because this is about the most common issue they deal with. They have to drop voltages of 5 and 6 cell lipo's down to a useable level, so..
One option is get a new Hitec servo like they're using in those 1/8 scales that is made specifically for high voltage. Option two is get a voltage regulator like was said earlier.
But to be honest with you I have never heard of anyone doing either one of those for 2 cell lipo? I only use Futaba BLS451 servo's and they handle the voltage fine.
jla8874 is offline   Reply With Quote
Old 07-11-2008, 06:33 AM   #6
Use a Switching BEC for bringing down 7V or more to 5.5V or so for radio parts.
Old 07-11-2008, 07:15 AM   #7
Trader Rating: 95 (99%+)
In the BJ4 your speed control will use it's internal BEC to regulate the proper voltage out to your receiver so it and your servo will have the proper voltage.
As for your robot, If all of your servos are hitec I believe they will handle the voltage straight out of the lipo with no problem. Check with Tony of Tony's Screws on here. He has been doing a lot of "testing" of the hitec servos with a 2 cell lipo in his 1/8th electric stuff. He could tell you if they will handle the voltage or not.
www.rcrcr.com --------> B-Mag free since fall '07
RobbieS is offline   Reply With Quote
flightpower evo 25c 4s 5000 pack big greg R/C Items: For Sale/Trade 10 09-08-2008 12:43 PM
Trackpower 4800 saddle pack Lipos GSM Storm Australia For Sale/Trade 1 08-26-2008 09:17 PM
TrackPower 4800 Saddle Li-Po Packs beaverltd Australia For Sale/Trade 6 07-17-2008 07:23 AM
