engine shutting down once its warmed up
newie here,
just wondering if anyone can give me a few reasons for my engine shutting down once it has warmed?? frustrated please help.:confused: |
Maybe ask in the nitro forums.
Most people around here run electric. :D |
Well if it is electric you motor sounds like a brushless motor and it is called thermalling it means you need to work on your gear ratio
oooh, oooh! I know, I know. The problem is you have a nitro engine in an electric car where the motor is supposed to be. Either that or you posted in the wrong forums.
How many gallons through it, sounds like you need a new piston and sleeve.
Guys help the guy don't be smart. He is a newie here. |
Sounds like you have stretched the con rod
motor runs while cold, warms up the compression goes up , motor stops,, The con rod is only Ali when you hit top RPM 18000+ and keep going with a hot motor(lean) its easy to do.... and fun Try only keep full motor RPM to only 2-3 seconds, then back off for a sec. more fuel(richer)keeps everything cooler and lubed, less top rpm, less fun less fuel(leaner) more fun, more speed, more heat, more damage,,,,,,,even balance is needed No more high speed passes all the way down the street at full noise. then lean it a bit more to go faster.(repeat) we all do it at first thats my bet. Oh yer this is the electric offroad:lol::nod: |
