Old 07-04-2008, 02:56 PM   #1
bluesxman's Avatar
Default Best Material for Balancing Tires?
I was wondering what people use to permanently add weight to balance their wheels/tires? I've seen people mention modeling clay to get the weight right, but it was unclear if then they added something else. I've also seen JB Weld mentioned. Are their tape on weights?
Basicaly, I'm looking for something that is easy to add, stays on the rim after rough use, and could be removed too, when I reuse my rims on new tires.
Also, I assume the place to add wieght is the inside of the rim against the side plastic?
bluesxman is offline   Reply With Quote
Old 07-04-2008, 03:08 PM   #2
MajorPede's Avatar
Ive used small screws with Krazy glue. Almost anything can work you just have to figure out how to mount it.
MajorPede is offline   Reply With Quote
Old 07-04-2008, 03:15 PM   #3
CraigB_3's Avatar
I've seen guys use lead tape from the local golf pro shop.....i think its used to add weight to golf clubs.
Dirt is for racin', asphalt is for gettin' there.
CraigB_3 is offline   Reply With Quote
Old 07-04-2008, 03:16 PM   #4
davepull's Avatar
go to a golf store or to like Dicks they sell stick on lead tape weight. works perfect
davepull is offline   Reply With Quote
Old 07-04-2008, 04:42 PM   #5
Gary NJ's Avatar
The best...
http://www.amainhobbies.com/product_...oducts_id/6977
Gary NJ is offline   Reply With Quote
Old 07-04-2008, 05:18 PM   #6
Slant EyEs's Avatar
Crayola Modeling Clay......
Sticks good and is fairly cheap.
-Jayson Pang-
Kyosho America - Peak Racing - KO Propo - AKA - DE Racing - Diggity Designs - Speedtech R/C - Team Slant EyEs
Slant EyEs is offline   Reply With Quote
Old 07-04-2008, 05:21 PM   #7
F N CUDA's Avatar
Trader Rating: 31 (100%+)
Just use modeling clay, clean the wheel and it stays forever and comes off ez.
Craig Hammon
F N CUDA is offline   Reply With Quote
Old 07-08-2008, 08:42 AM   #8
STRINGCHEESE's Avatar
I use storm lures fishing lure weights. Here:
http://www.basspro.com/webapp/wcs/st..._SearchResults
STRINGCHEESE is offline   Reply With Quote
Old 07-08-2008, 10:34 AM   #9
dizzy1's Avatar
Trader Rating: 24 (100%+)
I just use a hot glue gun. Sticks good, dries fast and can be removed if you reuse rims.
dizzy1 is offline   Reply With Quote
Old 07-08-2008, 10:44 AM   #10
RA99GT's Avatar
i use lead tape used for adding weight to golf clubs and tennis racquets
RA99GT is offline   Reply With Quote
Old 07-08-2008, 11:06 AM   #11
Suspended
+1 ...... it's really cheap
rocket-mtrsprts is offline   Reply With Quote
Old 07-08-2008, 01:53 PM   #12
tazz888's Avatar
Trader Rating: 22 (100%+)
3M Strip-Calk part# -08578 [black] works great. The cost of this stuff is 6.25a box that will last you forever and is avaliable from any good local auto parts store.
Crayola modeling putty does work great also.
tazz888 is offline   Reply With Quote
Old 07-08-2008, 01:55 PM   #13
How about this?...
1. Find the heavy side of the WHEEL only.
2. Find the heavy side of the TIRE only.
3. Place the tire on the wheel such that the heavy sides are opposite from each other.
4. Add/Subtract weights as necessary to obtain total system balance.
This should result in needing to add minimal weights for balance.
You could even do this across several sets of tires and wheels to find the combinations that would require the absolute minimal added weights...maybe even no added weights!
haulin79 is offline   Reply With Quote
Old 07-08-2008, 02:17 PM   #14
RobertjDrew's Avatar
Send a message via Yahoo to RobertjDrew
What's up? I have had great luck with using poster putty to balance my tires. It works great and holds excellent.
Later.
Robert Drew
Novak Electronics - Team Trinity - Upgrade R/C - RCID - Drew Racing
RobertjDrew is offline   Reply With Quote
Old 07-08-2008, 03:43 PM   #15
Ediaz's Avatar
how do you balance the tire/wheel?
Ediaz is offline   Reply With Quote
Best cleaning material? Shaunnyg723 Rookie Zone 24 07-22-2008 11:50 PM
Bumper material raffaelli Electric On-Road 6 05-10-2007 01:54 PM
What type of foam material are foam tires made from? pirate Electric On-Road 2 04-20-2007 09:40 PM
Softer Rim material? C Mike Hunt Nitro On-Road 0 04-24-2006 12:31 PM
Help, i need some material to promote RC ... Tabushi Nitro On-Road 0 12-13-2004 09:37 AM
