Old 07-18-2008, 01:27 PM   #271
kdeselms's Avatar
I've asked about that locally too, what happens when your stock Traxxas motor wears out? It's a sealed can - so do you then have to replace it with another of the same motor, or can you go get an equivalent motor from another manufacturer? If this impending AE truck is something that would run in the same class as the Slash, it's going to be bringing Reedy into the mix - so then you're going to have Slash owners wanting to use the Reedy motors instead, I imagine.
I think more than one manufacturer is going to lead to a thinning out of the CORR class rules a bit - it won't be a "box stock" requirement, but more related to weight, tires, motor and body type. I reckon it'll get to where, if you can make weight with your durability/looks hop-ups, using the predetermined tire/motor type, with the CORR body, then you're within spec. Just keep it simple.
Kevin Deselms
Associated Factory Team SC10
Webmaster, www.hotrodhobbies.com
kdeselms is offline   Reply With Quote
Old 07-18-2008, 02:27 PM   #272
Suspended
Personally, as long as everyone's using some sort of similar low-raction tire, and a big titanic body, and carry similar weight it seems as if the rest of it matters little. Let 'em bolt in all the ponies they want, they've still got to put the power to the ground ...
rocket-mtrsprts is offline   Reply With Quote
Old 07-18-2008, 06:10 PM   #273
Rommel's Avatar
+1
Rommel is offline   Reply With Quote
Old 07-18-2008, 06:33 PM   #274
OTE_TheMissile's Avatar
Send a message via MSN to OTE_TheMissile
+2
Faster Than Factory
On The EDGE Racing, est. 2001 - Home of the 524, the Silverado Slammer E-MAX6X6, and the Sand Dollar prerunner
Mike Budzien | facebook.com/OTE.TheMissile | RIVCO Products | The RC Corral | iRacing.com
OTE_TheMissile is offline   Reply With Quote
Old 07-18-2008, 09:02 PM   #275
TwoTone's Avatar
Just use a rules set similar to USVTA.
TwoTone is offline   Reply With Quote
Old 07-18-2008, 11:10 PM   #276
Suspended
Thumbs up
+3
"the words cheap and fast should not be used in the same sentence"
oxymoron is offline   Reply With Quote
Old 07-19-2008, 05:17 AM   #277
mfanke19's Avatar
Trader Rating: 24 (100%+)
+4
Matt Fanke
www.wiscalers.com
mfanke19 is offline   Reply With Quote
Old 07-19-2008, 07:00 AM   #278
glassdoctor's Avatar
Yeah, maybe on a dry loose track... but when a track is hooked up these can get around pretty well and I don't want someone hauling down the straight with a 6.5 strapped in and mow down whoever is in front of him...
When the track is good... I know i could use a lot more motor and turn faster lap times than stock.
These things are PERFECT for racing in full stock trim... beginner or old timer. They are "born" to be a SPEC class racer, imo.
glassdoctor is offline   Reply With Quote
Old 07-19-2008, 07:03 AM   #279
Suspended
spec racing never flies for long
and how many dirt tracks can claim having a good tacky track on a regular basis?
Originally Posted by glassdoctor View Post
-1
Old 07-19-2008, 07:23 AM   #280
BuckMan's Avatar
Exactly!! Remember, what works at your local track may not work at our local track.
Why are we even talking about rules.....
Trackside.com/crchobbies.com/LiveRC.com/RCScoringpro.com/Kal-Gard racing products
T.F.R. "Shockin' em' in '09"
Team Carbon "Need a little carbon-fiber in your diet?"
"Don't hate the pimp...hate the limp"
Your always welcome at zombo.com
BuckMan is offline   Reply With Quote
Old 07-19-2008, 10:05 AM   #281
stitchy's Avatar
Because we're bored and have nothing to do except squabble over rules on a car that doesn't exist yet. The spec thing has been beaten to death on the Slash thread too.
Speedtechhobbies.com
stitchy is offline   Reply With Quote
Old 07-19-2008, 11:25 AM   #282
when the "slash spec" class dies, fine. make it an open mod class. But right now, at many tracks it's working great as a box stock spec class. I don't know if it would be a good thing to have TWO slash classes in addition to all the existing ones.
And we water our track so it normally has good traction, and other tracks around that are indoors should be good also. So, a faster motor would indeed be an advantage at many tracks.
I've stated the same thing about running a faster motor on a loose track not being much advantage, if any... but that's only for a loose track. And, it's not always just lap times that matter. Running stock and mod together creates problems on the track because of the way they get around the track, even when the laps times are the same.
If rules are bad, then why even keep the stock tires? Just make it a "slash body" class and we can run anything we want under it. I have a 4wd chassis I would use...
I only posting a -1 as my opinion when others where posting +1, that's all.
Old 07-19-2008, 01:37 PM   #283
Suspended
these trucks aren't stock! these little doggies already have 12T motors, so what difference does motor choice make other that reducing longterm costs by allowing folks to run more reliable mills?
Old 07-21-2008, 09:24 AM   #284
Rick Hohwart's Avatar
I think you guys should wait until you see how the AE truck is equipped, its size, etc. before talking about rules etc. This thread could even be in the wrong forum "Micro and Mini Scales" here we come!
It is a good read though
Rick Hohwart is offline   Reply With Quote
Old 07-21-2008, 09:36 AM   #285
stitchy's Avatar
muhuhahahahaha
New Losi Desert Truck 1/10 Drift_Buggy Electric Off-Road 84 08-21-2008 07:39 AM
WTB Losi 1/10 Desert Truck manynitros R/C Items: Wanted to Buy 0 08-19-2008 11:06 PM
Nitro Desert Truck? thecman26 Nitro Off-Road 2 07-06-2008 12:36 PM
Got Losi Desert Truck, Need Batteries... vokus Rookie Zone 4 06-20-2008 09:19 AM
1/36 Micro-Desert Truck raceGEEK Micro and Mini Scales 3 11-07-2007 05:15 PM
