Old 07-02-2008, 09:53 PM   #1
Default The largest shocks made for rc vehicles?
I'm not involved in rc cars anymore but was a few years back. Right now I'm loooking for a damper for a mechanism I'm engineering and think that a very large rc car/truck-type shock would be something to consider strongly because they have such mpressively low stiction.
Can anyone tell me what vehicle has the largest oil dampers available? Or what simply the largest shocks I can buy by themselves are? The ideal would be something with a good couple inches of piston travel. But if that's not available I'd still like to see what's out there.
vkg1 is offline   Reply With Quote
Old 07-02-2008, 09:58 PM   #2
Suspended
Send a message via AIM to plack75
try anything 8th scale... try the hpi savage.. they have good piston travel
plack75 is offline   Reply With Quote
Old 07-02-2008, 10:16 PM   #3
Nik
Nik's Avatar
Team Losi LST2 shocks. Just what your looking for. Aluminum bodies. The Aftershock has the same shocks except plastic bodies (cheaper)
I can ride my bike with no handlebars.
Nik is offline   Reply With Quote
Old 07-02-2008, 10:20 PM   #4
Trader Rating: 16 (94%+)
LST2.
BSS07 is offline   Reply With Quote
Old 07-02-2008, 10:28 PM   #5
jnev's Avatar
Trader Rating: 25 (100%+)
LST2/Aftershock shocks are the biggest ones I know of as well. You may also want to look at Baja 5B shocks. The diameter of them is smaller than the LST2/Aftershock shocks, but they are quite long and have a lot of travel...
jnev is offline   Reply With Quote
Old 07-03-2008, 04:47 AM   #6
Drifting101's Avatar
Originally Posted by BSS07 View Post
LST2.
Biggest i have seen with out going to big like 1/5 or large cens
::Mi4::17.5::::::M03R::HW 3000kv::::::T4::7.5::::::HB Cyclone D4::5.5::
"Why follow, when you can lead?"
Schumacher
Drifting101 is offline   Reply With Quote
Old 07-03-2008, 11:00 AM   #7
If you want ZERO stiction, I would go for a non-contact electomagnetic brake/damper system...there are NO physically contacting parts thus zero stiction.
haulin79 is offline   Reply With Quote
Old 07-03-2008, 11:04 AM   #8
Suspended
WTF ???
rocket-mtrsprts is offline   Reply With Quote
Old 07-03-2008, 12:53 PM   #9
STRINGCHEESE's Avatar
Originally Posted by rocket-mtrsprts View Post
WTF ???
just cause you don't understand doesn't mean you have to type rocket
STRINGCHEESE is offline   Reply With Quote
Old 07-03-2008, 01:29 PM   #10
wingracer's Avatar
Trader Rating: 24 (100%+)
If you need more travel than a LST2 shock will give then try 1/5 buggy shocks. Should give you the 2 inch travel you are looking for
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 07-03-2008, 02:17 PM   #11
WTF ???
These guys are a customer of mine.
Narly1
http://www.kinetics.ca/
MR Fluid Semi-Active Dampers
Under an agreement with Lord Corporation, the world’s largest developer of magnetorheological fluid, General Kinetics can now offer our customers MR-fluid based semi-active damping systems. MR fluid changes state from liquid to a semi-solid (and back) in microseconds under a low-power magnetic field, making it an ideal working fluid for semi-active dampers.
A low number of moving parts provides mechanical simplicity consistent with superior reliability. Many years of concentrated development efforts have resulted in systems with sub-10 millisecond response times, and in conjunction with proven General Kinetics military damping hardware, provides a system with superior durability across the range of extreme conditions experienced by modern military vehicles.
Both leaders in their respective fields, General Kinetics and Lord Corporation make an ideal combination to offer the military advanced suspension technology.
Performance Curves
APPLICATIONS
Light armored vehicles
Tactical Trucks
Armored personnel carriers
Self-propelled howitzers
Tracked & Wheeled Combat Systems
FCS/FTTS Technology Insertion
Narly1 is offline   Reply With Quote
Old 07-03-2008, 06:28 PM   #12
scott54's Avatar
Originally Posted by Narly1;4600847
[url
http://www.kinetics.ca/[/url]
APPLICATIONS
Tactical Trucks
WOW!! Cool website......................... I'm in the wrong hobby!
TLR Racing - ARCS Speedway - B-Fast Racing - Dialed RC - G-Force
scott54 is offline   Reply With Quote
Old 07-03-2008, 09:44 PM   #13
Suspended
just because you want to post something totally off topic, like tank shocks, doesn't mean you have to type cheesy
Old 07-08-2008, 12:07 PM   #14
tdeal823's Avatar
Trader Rating: 30 (100%+)
Hpi 5B is a 1/5 buggy these shocks are a good size bigger and more travel than a lst shock
tdeal823 is offline   Reply With Quote
Old 07-08-2008, 05:55 PM   #15
you could in theory make your own electomagnetic brake/damper system....
-take existing shock,
-wrap wire around the shock body(or use shock spring itself)
-connect ends to a power source that is variable
-fill shock with grey goo(ferrous material suspension)Think iron filings in oil
-continue with build of shock as usual.
Simply putting current through the coiled wire(electromagnet) will stiffen up suspension, more current=more dampening.
This is a VERY simplified explanation...what you do not see is the vast amount of money used to research the electronics that control how strong the magnetic field has to be depending on the road surface....
dubluv is offline   Reply With Quote
largest lipo that will fit in a b4? racer34v Electric Off-Road 10 05-23-2008 08:21 AM
Largest Electric series in the USA. Exterminator Electric Off-Road 13 02-29-2008 08:51 AM
Largest X-ray T2 parts package you have ever seen imprsme R/C Items: For Sale/Trade 19 11-08-2006 04:37 PM
Largest Spur in Yokomo CGM? [RC10TC] Electric On-Road 2 08-11-2006 10:33 AM
Largest RC manual archive on the net! wyattburp Web Links 2 06-22-2006 07:29 AM
