Old 07-01-2008, 11:51 PM   #1
Bodies by Dana's Avatar
Default Traxxas Slash Improvements
I have found some weak points about the slash that could be fixed, and I was wondering if any of you fixed some spots on the slash as well. Does anyone want to share some tips?
I have a tip for everyone, the gear cover on the slash has a hole by the driveshaft. I think that is what is letting all the dirt in. So, with some help from my dad, and the idea from a friend, I bought the RPM Traxxas Rustler gear cover and put it on the slash. My buddy did this and the motor shaft wore a hole through the cover, so when I did it, I cut it a little bit shorter. That made room for the cover to fit over it.
But when I went to put the cover on, I noticed that a piece of plastic surrounding a screw was bumping into the cover, thus making the holes in the gear cover, unable to line up with the holes in the transmission case.
This made me take the rear bumper of by only 6 screws, and just dremeled out the exces plastic by the screw.
The gear cover fits perfectly now. I have not yet run it, but plan to today.
If anyone else has tips, please share. Thanks.
Rule #1: Never let little kids drive fast cars unless you ask them if they know how to drive and they say yes.
Rule #2: Little kids are liars. Don't let them drive anyway.
Oil your receivers weekly! I use 30wt...
Bodies by Dana is offline   Reply With Quote
Old 07-02-2008, 12:25 AM   #2
nobike's Avatar
Trader Rating: 147 (100%+)
nobike is offline   Reply With Quote
Old 07-02-2008, 07:52 AM   #3
Miller_Time's Avatar
Trader Rating: 11 (92%+)
I think it's easier to just put some duct tape on the stock gear cover. I wish Traxxas would redesign it similar to the indention of the RPM instead of a gap, it's been like that for years.
For the motor shaft clearance on the RPM cover, you can heat up the plastic with a lighter and push it out slightly with something like a ball point pen on the blunt end.
The only other suggestions I have on the Slash is to put loctite on the wheelnuts, shock mount screws, and rear suspension hinge pins. They will back out over time - something about the plastic that Traxxas uses doesn't hold screws well.
Miller_Time is offline   Reply With Quote
Old 07-02-2008, 11:29 AM   #4
Trader Rating: 39 (100%+)
Send a message via AIM to Zac R Send a message via MSN to Zac R
http://www.rpmrcproducts.com/products/traxxas/Slash.htm
92zero Designs - AKA - O.S Engines - Futaba - Team Orion - B-Fast R/C LiveRC.com - RC Scoring Pro - TFR
92zero Deisgns
Decals - Clothing - Pit boards - Wraps - Signs - Banners & More
Zac R is offline   Reply With Quote
Old 07-02-2008, 04:05 PM   #5
no gear cover though, thats what they should make next. My dad emailed them about a gear cover, and they said its HIGHLY likley they will make one for the slash. I hope they do.
Old 07-03-2008, 03:01 PM   #6
Company Representative
ballisticsart's Avatar
Trader Rating: 20 (100%+)
I found some awsome beadlock wheels for the slash at rpphobby.com ther cnc'd delrin with aluminum rings super trick looking
CFO - P1hobbies.com
P1raceway.com
Mercenary
ballisticsart is offline   Reply With Quote
Old 07-03-2008, 03:21 PM   #7
Suspended
I found the steering rack would "pop out" from the chassis where the cap heads are supposed to index into the chassis.
My solution was to find some 30mm screws and using some shims I am running screws through the top deck of the chassis, through the steering rack, and into the skid plate. This ties the skid plate into a third point, keeps the steering rack rock solid, and looks much more professional.
I was thinking of doing a write up with pictures...but honestly it's a easy enough fix that anyone with the screws and some ingenuity can figure it out..only took me 15 minutes to do it. Just required two 30mm screws, two 2.5mm shims, and the aluminum steering rack.
Wes Briscoe is offline   Reply With Quote
Old 07-30-2008, 11:13 PM   #8
HarKonnenD's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to HarKonnenD
Double check the gear mesh and tighten the motor screws. Mine were tight, but not tight enough causing me to slightly strip the gear after some hard landings. If you want better traction and don't mind leaving the stock tires, New Era makes an adapter to use 8th buggy tires for the vehicle - they are the same size.
Trying to live every day like its the last....
HarKonnenD is offline   Reply With Quote
Old 07-30-2008, 11:23 PM   #9
Tech Legend
Wild Cherry's Avatar
Shock shafts bend real easy ...
Easy to bend them back by hand though...
Transmission needs to be tape up to seal it from dirt..
Add 100,000w to diff gears...
Any driver can copy a great set up, a Champion however will steal it .
If Jesus returned as a Rc car he be a Rc10 B5M
George W. Cherry
Wild Cherry is offline   Reply With Quote
Old 07-31-2008, 04:18 AM   #10
RCRat's Avatar
Send a message via AIM to RCRat Send a message via Skype™ to RCRat
What weight shock oil?
What weight oil for better bashing?
RCRat is offline   Reply With Quote
Old 07-31-2008, 06:29 AM   #11
This is the best improvement...
http://slashracer.proboards80.com/index.cgi?
rm25x is offline   Reply With Quote
WTT Traxxas Slash for T4,B4 or B44 Blade Bomber R/C Items: For Sale/Trade 13 09-12-2008 12:26 PM
Traxxas Slash XL-5 hlpressley R/C Items: For Sale/Trade 15 08-22-2008 08:39 AM
Traxxas Slash and Traxxas Jato 3.3 SerpentCT4S R/C Items: For Sale/Trade 9 08-13-2008 02:39 PM
Traxxas Slash WTB axle182 R/C Items: Wanted to Buy 6 06-27-2008 06:36 PM
