Old 07-04-2008, 10:42 PM   #61
Suspended
Originally Posted by vtec_chump View Post
I have a somewhat related question. How do you guys remove ball cups from the studs without bending and scraping (pliers) the cup itself? Is there a tool that does it without too much damage to either parts?
I made a fork-looking tool. Pops them right off, neat and clean, no marks.
rocket-mtrsprts is offline   Reply With Quote
Old 07-05-2008, 06:09 AM   #62
Doodad's Avatar
Send a message via Yahoo to Doodad
Assoc. turnbuckle wrench works great.
Doodad is offline   Reply With Quote
Old 07-05-2008, 09:05 AM   #63
Mertz's Avatar
I've been rockin the j-concepts white ball cups on the 2whl and 4whl, and i've only popped one off, none broke or bent.
Tim Mertz
Team Orion/Xtreme Paints/Impact Graphics/Team Young Gunz!/Long Island Raceway & Hobby
Mertz is offline   Reply With Quote
Old 07-05-2008, 09:26 AM   #64
superdave2's Avatar
i run the RPM ones they work great ive been running them for the last 3 years about
Team Terribles~ARCS Hobbies~Have Fun Hobbies~Answer-RC~Torco Fuel~Fastlane Graphix~ Caster Racing Products~Maxamps~Clockwork Racing Engines~BCG Industries
losi 8t dps .28 jr z9100s jr z9000t
spektrum dx3
superdave2 is offline   Reply With Quote
Old 03-28-2009, 07:12 AM   #65
E-clip's Avatar
Trader Rating: 39 (100%+)
Default BAllends for a corally
How do I find out if the ball studs are Metric or Imperial size ???
I want to use RPM ballends but I'am not sure weather they will fit on an Corally RDX PHI car
Does any one know if they will fit ???
If not what are better than the original corally Ballends
E-clip is offline   Reply With Quote
Old 03-28-2009, 08:44 PM   #66
rob martin's Avatar
Trader Rating: 57 (100%+)
Send a message via AIM to rob martin
as long as there fresh(not worn out) I've had good luck with rpms/associated and jc concepts.
Rob Martin~
~Ridgeway bodies~B-Fast Performance Diffs~Flying Farmer Traction Sauce
rob martin is offline   Reply With Quote
Old 03-29-2009, 07:02 AM   #67
Hate2Looz's Avatar
Trader Rating: 27 (97%+)
No luck with the RPM's, or AE but the J Concepts are the best I have found
so far.
Hate2Looz is offline   Reply With Quote
Old 03-29-2009, 05:20 PM   #68
Gliptal's Avatar
The RPM ball cups are the toughest I've used but they do wear out quick. I've had mixed results with the AE ball cups, the last kit I bought (b4 early this year) they were garbage. They split right down the middle, I've never seen them do that before.
Also, if a ball cup is tight when you put it on the stud, squeezing it with a pair of pliers will loosen it up.
Gliptal is offline   Reply With Quote
Old 04-01-2009, 08:29 PM   #69
XXXDad's Avatar
Trader Rating: 195 (100%+)
Losi HD's
☆ Glenn Carlson ☆☆ WPB, Florida☆
☆TLR 22B 3.0 MM ☆ 22T 2.0 MM ☆22B 2.0 MM ☆22-4 ☆ SCTE 2.0☆ ☆
XXXDad is offline   Reply With Quote
Old 04-01-2009, 08:35 PM   #70
xDaRReLLx87's Avatar
Originally Posted by XXXDad View Post
Losi HD's
+1
Really Durable, larger area
Hyper 9E 2000KV T8/RX8- 4S Turnigy 4500 mah
Ko ProPo EX-1 UR 2.4 ghz, Hitec-7950TH
xDaRReLLx87 is offline   Reply With Quote
Old 04-02-2009, 01:17 AM   #71
tom_chang79's Avatar
A fresh set of ball cups, ball studs, and turnbuckles should NOT popoff under NORMAL circumstance.
There's probably another issue at hand. The most likely cause is a geometry problem, either from flexing too much (which changes the intended range) or you have a worn out or broken section of the suspension which is causing the alteration of a geometry. Also, you might want to check to see if you need limiters in your shocks, inside and/or outside the shock, depending on where the problem is, during droop or full compression.
I kept popping my RPM ballcups fitted onto AE ball studs with AE titanium turn buckles, and it turned out that the rear suspension arm was torn, but not too extreme that it was obvious. I didn't realize this until I started to wonder why suddenly the ball cups were popping off in that particular side, in that particular area for doing absolutely nothing but running the car.
A torn arm caused the geometry of the rear suspension to be altered ever so slightly, which in turn forced the ball cup to pop off on that side. Once replaced, no more popped ball cup.
But after long lengthy use, it is worth it to change out the ball stud and the ball cup simultaneously if you suspect normal wear is what's causing them to pop off. During racing, in a pinch, I used to take a plastic shopping bag and just cover the top of the ball stud with it, pop the ball cup on it, then tear off any excess shopping bag. This was a trick that I did 15 years ago, but it's a temporar fix that will eventually require a full replacement....
RIP TAP RC
tom_chang79 is offline   Reply With Quote
FM Radio, pinion gears, turnbuckles, ballcups JDub765 R/C Items: Wanted to Buy 4 02-29-2004 01:20 PM
RPM ballcups fReShJiVe Singapore R/C Racers 0 01-24-2003 07:17 AM
