Old 07-02-2008, 06:17 AM   #16
Trader Rating: 16 (94%+)
yeah the jconcepts ive been using the past 3 weeks and all they did was bend and pop off
BSS07 is offline   Reply With Quote
Old 07-02-2008, 06:20 AM   #17
LOSI SCOTT's Avatar
Trader Rating: 70 (99%+)
Losi white work great on my XXX-T
LOSI SCOTT is offline   Reply With Quote
Old 07-02-2008, 06:56 AM   #18
PW
PW's Avatar
Send a message via AIM to PW
If you are have the problem with 2 different brands then something isn't right on the car. Check that you have the proper length turnbuckles; if the turnbuckle is threaded in to far they pop off easy and if they aren't threaded far enough in the ball cups break or bend.
Paul Wynn
JConcepts - Team Associated - Reedy - XP - TSR Products - MIP - Stickit1
P1 Brand - "If it's only for fun; then take out the transponder?!"
PW is offline   Reply With Quote
Old 07-02-2008, 07:03 AM   #19
Suspended
Both Associated and Losi make heavy duty versions of their ballcups that are a wee bit stouter than the stockers. And while the RPM ones are likely the best on the market, durability-wise, it would still be my educated guess that whatever it is that's breaking the stock ones will also lead to breakage of whatever else you use or something else on your truck.
My advice would be to clean up your driving, because I can't see that AE would have let a built-in failure problem slip between the design cracks and out the door. I've always found it funny that at the club level how many people have such problems, breaking things left and right, and yet you go to a bigger race and literally no such problems.
rocket-mtrsprts is offline   Reply With Quote
Old 07-02-2008, 07:14 AM   #20
LOSI SCOTT's Avatar
CLEAN DRIVING THATS THE TICKET TO EVERYTHING
Old 07-02-2008, 08:12 AM   #21
Jason Pelletier's Avatar
Trader Rating: 33 (100%+)
Originally Posted by SQC049 View Post
I use RPM ball cups on both my B4 and T4.
Thats wht i have on my b4 and one hasn't popped off yet. broke the tie rod before that popped off at vineland....
Island Raceway & Hobby
Jason Pelletier is offline   Reply With Quote
Old 07-02-2008, 08:29 AM   #22
Suspended
That seems counter-intuitive to how it should work, or at least how they're intended or designed to work.
Old 07-02-2008, 08:41 AM   #23
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
I use these as well. I also have used the Losi white ball cups and the J Concepts ones as well with no problems. If you don't pop them off much they will stay tight and not come off.
Another problem is to make sure you don't have metric ball studs with American sized ball cups or vice versa as that will cause a problem for sure.
ST Racing Concepts (STRC)
Old 07-02-2008, 08:46 AM   #24
badassrevo's Avatar
I use the white losi cups with the Losi titaniun ball studs. I drill a hole in the top of the ball cup so you can remove the ball stud and install or remove shims for tuning with out popping the cup off. It works very well.
This is on my T4.
Doug Lightcap
ARCS Hobbies / Paint Monster Airbrushing / BFast / Tonys Screws
badassrevo is offline   Reply With Quote
Old 07-02-2008, 10:24 AM   #25
Tubaboy's Avatar
what are the best ballcups you can get for a t4 and a b4? mine either bended or keeps popping out
RPM & JConcepts are both great.
Paul
www.wyomingrc.com | www.wyomingmodelerspark.com
Tubaboy is offline   Reply With Quote
Old 07-02-2008, 01:05 PM   #26
OG RC 10T's Avatar
Trader Rating: 41 (100%+)
RPM
Original RC 10T, T4, RC8Te, Tekin RX8. Losi Ten SCTE, Slash 4x4.
OG RC 10T is offline   Reply With Quote
Old 07-02-2008, 01:32 PM   #27
LOL, it's ok it was at vineland.... ever see those jumps.....
I know this guy and his ballcups kept popping off at vineland. That's why he posted.
I also remeber another guy i race with broke a ti tierod with a kyosho ball cup. I the gweed did it too cause i gave my 2 spares to them. It happens but that just shows how good the rpm cups are.
Old 07-02-2008, 01:39 PM   #28
kuzo's Avatar
Send a message via MSN to kuzo
I've always preferred these for the best protection:
kuzo is offline   Reply With Quote
Old 07-02-2008, 02:13 PM   #29
DdasHizEl714's Avatar
Default jconcepts
The j concepts white or black ones it doesnt matter as long as they arent the yellow ones those are ugly as hell,they are bomd diggity and they come with the trick mugen sytle ones for the rear.
OC/RC RACEWAY
DdasHizEl714 is offline   Reply With Quote
Old 07-02-2008, 02:14 PM   #30
lol i was driving clean, if i landed a jump perfect they would pop off
FM Radio, pinion gears, turnbuckles, ballcups JDub765 R/C Items: Wanted to Buy 4 02-29-2004 01:20 PM
RPM ballcups fReShJiVe Singapore R/C Racers 0 01-24-2003 07:17 AM
