Old 06-30-2008, 02:00 PM   #1
rjs_13203's Avatar
Default lipo questions????
just bought a trakpower 4900. want to know if its ok that it goes over 4900 mah? also can i use this in a heat race then charge it again right after for another and so on? sorry new to this my first lipo, recently bought a
eos0606i charger for it. also is there anything i should know about this such as charge rate and what not?
rjs_13203 is offline   Reply With Quote
Old 06-30-2008, 02:17 PM   #2
badassrevo's Avatar
You should not see more than 4900 mah go back into the pack. Yes you can run and charge and run and charge all day long.
You should charge at 4.9 amps.
Doug Lightcap
ARCS Hobbies / Paint Monster Airbrushing / BFast / Tonys Screws
badassrevo is offline   Reply With Quote
Old 06-30-2008, 02:23 PM   #3
Ed237's Avatar
The only way a 4900 mah lipo would take more than 4900 Mah is if the cell(s) went bad or if the charger was not set up correcctly. Thats because you should never ever completely discharge a Lipo.
You can charge your lipo a few days before a race and put it on the track without re-peaking it with virtually no loss of performance. And you can start re-charging the battery as soon as you pull your vehicle off the track. They actually charge better when they are warm.
Sorry, I have no exerpience with that charger.
Ed Toth
LCRC Raceway and Bumps & Jumps.
Ed237 is offline   Reply With Quote
Old 06-30-2008, 02:26 PM   #4
jnev's Avatar
Trader Rating: 25 (100%+)
On my Flightpower 4s 4270mah pack, about 4900mah went back into it. It seems normal to me, as in it still works perfectly (although it was the first time I charged the pack since it is brand new)... The cutoff is at 12 volts, and I ran the whole pack.
jnev is offline   Reply With Quote
Old 06-30-2008, 02:28 PM   #5
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
If you using a Hyperion charger make sure you set it up for 2 cell lipo and that you only put in 4900 mah for the battery size. The charger will take care of the rest once you start to charge. I use Hyperion chargers and they work great.
Just make sure you set at:
2 cell, lipo setting, 4900 mah and your good to go.
ST Racing Concepts (STRC)
Old 06-30-2008, 02:31 PM   #6
morris's Avatar
Trader Rating: 40 (100%+)
yup sounds right to me....
AE/VIPER/XPERT/DIRTCHEAPRC.COM/JCONCEPTS
A big thx to all the tracks that I race at:cause if it wasnt for these guys..we wouldnt have a place to race our r/c cars!!!
morris is offline   Reply With Quote
Old 06-30-2008, 02:32 PM   #7
rjs_13203's Avatar
well i charged it up and it went to 5000? plugged it in and worked fine is this something i should worry about? i know with nimh u usally can get more out of them then what ir says
Old 06-30-2008, 03:09 PM   #8
jla8874's Avatar
Trader Rating: 23 (100%+)
Even if it only went to 4900 you should be worried because that means it was discharged to ZERO! That would not be good.
jla8874 is offline   Reply With Quote
Old 06-30-2008, 03:15 PM   #9
Team Tekin
yzracer758's Avatar
Trader Rating: 18 (100%+)
Do you have a Lipo cutoff on your esc? Not having one could be the source of your problem.
Tekin, Inc. | XRAY | RC America | Hudy | Protek RC | Exotek Racing | Factory-RC Products | Proline Racing | Avid RC | Vision Racing Products | Paint By Smiley | SOR Graphics |
Jeremy Potter
yzracer758 is offline   Reply With Quote
Old 06-30-2008, 03:15 PM   #10
rjs_13203's Avatar
if that were so wouldnt not even charge? also it never got warm
Old 06-30-2008, 03:16 PM   #11
rjs_13203's Avatar
yes i have a lipo cut off set at 6v its a mm
Old 06-30-2008, 03:17 PM   #12
rjs_13203's Avatar
so what u say is that my charger should just stop at 4900?
Old 06-30-2008, 03:17 PM   #13
chris moore's Avatar
Trader Rating: 88 (99%+)
Can you say lipo fire
exactly!
chris moore is offline   Reply With Quote
Old 06-30-2008, 03:17 PM   #14
Team Tekin
yzracer758's Avatar
Sounds like your battery might be a dud.
Jeremy Potter
Old 06-30-2008, 03:20 PM   #15
rjs_13203's Avatar
even though it still works fine?
Few lipo questions ClayKann101 Radio and Electronics 8 09-11-2008 06:08 AM
lipo questions....???? sparkzilla500 Radio and Electronics 6 05-31-2008 10:36 PM
LIPO Questions Drifting101 Radio and Electronics 9 05-28-2008 01:47 AM
Going Lipo. Few questions. slaytanic Nitro Off-Road 7 03-10-2008 12:46 PM
LIPO Questions RCNUT Electric On-Road 1 08-17-2007 12:47 PM
