Old 06-30-2008, 03:33 PM   #16
My understanding of LiPo batteries is that damage due to over-charge/discharge is cumulative. Over discharge will damage the battery but fire is not a danger. Over charging can cause the lithium to form metal fragments which are very volitile. Your battery may have worked fine the first time or maybe a few times afterward, but I think you're pushing your luck by continuing to use it.
I have a TP 4900 and it has never charged more than ~4200mah. Take it back to the manufacturer.
TLR-22T, RB5/ZX5, DEX408
Spectrum DXR3R
OCRC/WCRC
bprocket is offline   Reply With Quote
Old 06-30-2008, 04:44 PM   #17
jla8874's Avatar
Trader Rating: 23 (100%+)
So you've only charged it one time? Run it down, and charge it back up a few times and then see what the deal is. If there is a problem with it I can assure you TP will make it right for you. They have top notch customer service. I have two TP 4900's myself, and honestly I cant recall ever hearing one bad thing or problem with them ever. Yours would be a first if it is the lipo. Something just doesnt sound right about this whole thing? I have three Hyperion EOS 5i's and the same lipos and I cant see how this could be?
jla8874 is offline   Reply With Quote
Old 06-30-2008, 05:05 PM   #18
rjs_13203's Avatar
right well im going to see how it goes after a couple of charges and discharges if it still dont seem right im going to call tp
rjs_13203 is offline   Reply With Quote
Old 07-01-2008, 06:44 AM   #19
nitrobeast's Avatar
Trader Rating: 41 (100%+)
Originally Posted by jnev View Post
On my Flightpower 4s 4270mah pack, about 4900mah went back into it. It seems normal to me, as in it still works perfectly (although it was the first time I charged the pack since it is brand new)... The cutoff is at 12 volts, and I ran the whole pack.
Is this a 2 cell? What cutoff is at 12 volts?
Rui Goncalves
Team CRC|Awesomatix USA|TQ Wire|
Jackson curbs, ready for lift off!
nitrobeast is offline   Reply With Quote
Old 07-01-2008, 08:49 AM   #20
jla8874's Avatar
Also, I noticed somebody on another thread told you they routinely put
5500mAh in to their TP 4900. Dont take everything people post as fact. That sounds completely screwed up to me as well.
Old 07-01-2008, 08:53 AM   #21
Suspended
Originally Posted by jla8874 View Post
Also, I noticed somebody on another thread told you they routinely put 5500mAh in to their TP 4900. Dont take everything people post as fact. That sounds completely screwed up to me as well.
I'd like to know how anyone actually knows for a fact that their lipo takes anything more than about 1/2 the mAh rating?
The only way they could get any total capacity reading is IF they totally discharged their pack, recharged it from dead and then noticed the obligatory swelling of the cells prior to combustion.
This whole thread smells fishy, and most of the answers sound as if they're coming from non-lipo users or owners ...
rocket-mtrsprts is offline   Reply With Quote
Old 07-01-2008, 09:16 AM   #22
DavidAlford's Avatar
Trader Rating: 31 (100%+)
Send a message via AIM to DavidAlford
Your Hyperion charger is going to stop charging at 8.4 volts. Thats when the pack maxs out. Your never going to put 4900 mah in it. I ran lipo for the first time last week and I'd recharge my pack with a hyperion after every run. It would put about 2000mah back in and peak out at 8.4 volts. So just make sure it doesn't get overly hot while charging and keep an eye on your volts and enjoy your pack.
Hot Bodies/HPI | Jconcepts | Viper RC | Xpert | Sippel Speed Shop | Lawton RC Raceway | SXT
DavidAlford is offline   Reply With Quote
Old 07-01-2008, 09:30 AM   #23
Davidka's Avatar
Trader Rating: 77 (100%+)
Ditto that. The charging pattern the CC-CV charges work on do not "force" power into the battery beyond 8.4v. If the battery's charge cycle acts normal (amperage falls off steadily while voltage stays @ 8.4v) then don't worry about what the mah reading says, it may not be very accurate anyway.
Old 07-01-2008, 09:56 AM   #24
rjs_13203's Avatar
thanx guys im going to use it and watch for swelling i think maybe the mah reading was off cuz wasnt hot or swelling.
Old 07-03-2008, 05:48 PM   #25
Trader Rating: 22 (100%+)
Send a message via ICQ to cmain
Another possibility (although unlikely) is they somehow mixed up the cells at the manufacturer flightpower makes both the trackpower 4900 and checkpoint 5400.
cmain is offline   Reply With Quote
Old 07-04-2008, 07:18 AM   #26
Krio's Avatar
Trader Rating: 150 (99%+)
the fact that lipos take more than what they are rated after a full discharge to their respective cutoff voltages is nothing to worry about. So long as the packs aren't overdischarged (which they aren't with the mm cutoff set) it is NORMAL for packs to go past their rated capacity upon charging. I personally have 2 trackpiwer 4900's I race with and after practicing with them until cutoff I regularly see roughly 5100mah go back into them. An extreme example was a maxamps 6000 pack I had. I saw 6800 (!!!!) go into that thing more than 20 times. Your pack is perfectly fine. Charging to 5000mah is perfectly normal. Enjoy that gold brick!
www.kriostasis.com
Krio is online now   Reply With Quote
Few lipo questions ClayKann101 Radio and Electronics 8 09-11-2008 06:08 AM
lipo questions....???? sparkzilla500 Radio and Electronics 6 05-31-2008 10:36 PM
LIPO Questions Drifting101 Radio and Electronics 9 05-28-2008 01:47 AM
Going Lipo. Few questions. slaytanic Nitro Off-Road 7 03-10-2008 12:46 PM
LIPO Questions RCNUT Electric On-Road 1 08-17-2007 12:47 PM
