What is best starting point for gearing?
on a ft b4 with a 12x2 checkpoint?
I would start with an 18T, but thats just me.
18/81 - 21/81 depending on the track you are running on
i have a 21 in it now but the motor seems to get hotter than i like
yea my motor gets hott to... so does my friends. its almost untouchable when it comes off the track
is that ok or should i drop it down to a 20t?
i dont think it would hurt if you are only running it in a 5 min race
will dropping it make it hotter?
This is how i work it out for a brushed (wich is like never)
http://www.ultimaterc.com/forums/showthread.php?t=62860
The lower the teeth on the pinion the cooler the motor will run. The higher the teeth on the pinion the hotter the motor will run.
If your motor is really hot drop a couple of teeth on the pinion and you will run lower temps.
If its almost untouchable your gearing is way to high, and the excessive heat will burn out the motor prematurely.
Try an 18t pinion and go up from there.
