Old 06-17-2008, 02:46 PM   #1
rcracer3533's Avatar
Default Lipo question
Im new the the lipo era and was wanering if its safe to run a lipo battery with any esc. Wanted to make sure I didnt need some special product to use a lipo battery with say an lrp 7.1 esc or a novak sport esc that comes in the losi rtr trucks. thanks.
rcracer3533 is offline   Reply With Quote
Old 06-17-2008, 02:51 PM   #2
Trader Rating: 18 (100%+)
You should be fine. A 7.4v lipo will only be 8.4v when charged, whereas a 7.2v nimh will be around 9v. The only thing you have to worry about is the current limit of the speedo. Just stay within recommended motors and you should be fine.
trilerian is online now   Reply With Quote
Old 06-17-2008, 04:18 PM   #3
Super Moderator
The only issue is low voltage cutoff. Lipos can't be ran down all the way or they won't charge back up again. Most newer speedos have a low voltage cut off setting, check your manual. Or perhaps others here can comment on the speedos you mentioned. Usually around 3 volts per cell, or 6 volts for a typical pack.
Alternatives: Some, such as Novak, make an add on product that will shut down the speedo. Or, just be careful with your run time, run a timer and limit how far you discharge. If the car seems to slow at all, stop immediately. Go pick it up and unplug it, don't even drive it back.
Dave H is offline   Reply With Quote
Old 06-18-2008, 04:37 AM   #4
ROV
ROV's Avatar
All good advice
Lipo's are fickle things they do no not like to run down at all,,yup 3v-3.4 to be safe...
If you see any ,,ANY, drop off in performance stop immediately and recharge, lipo cutoff is a must saving many batts,,,,other wise you will deplete its life. it will puff up probably and soon die ,becoming unsafe to charge in the meantime......I should listen to my own advice Ive killed plenty $$$
TELL THEM ROV'S HERE AND HE'S RUNNIN WHEELS THAT ARE READY TO RACE !!!
CEO TRASH TALK TOURING HOME OF WA'S CHEAP TRASH PISSTAKES
AM PSYCLONE,HOTBODIES D4,NOVAK,LRP,HACKER,MEGA,EFLIGHT.JR,KOPRO,HITECH, SPEKTRUM,TRAKPOWER,OS,CDC,SWASHDRIVE JET,ZENOHA,WEMOTECH DUCTED,LIPO4GO,LOSI,KOKOM,CDC,5IVE,8IGHT,XXCR,LST,CASTLE
ROV is offline   Reply With Quote
Old 06-18-2008, 05:18 PM   #5
RCBLUE's Avatar
The LRP 7.1 is too old to have lipo cut off. I would look into getting the add-on monitor as mentioned earlier.
Don't sweat the petty things...........Pet the sweaty things!!
Serpent America
Lunsford Racing
RCBLUE is offline   Reply With Quote
Old 06-18-2008, 07:38 PM   #6
Bulldawg RC's Avatar
Trader Rating: 65 (99%+)
+1
http://www.BulldawgRC.com
Bulldawg R/C Batteries and Products
Nimh and Lipo Batteries and accessories
www.BulldawgRC.com
Team Driver for: Proline, Team Epic/Trinity, Hex Crew, Bulldawg R/C, Speed Demon Hobbies ~~~~TEAM CRUNCHY~~~~
Bulldawg RC is offline   Reply With Quote
Lipo question. MRorange Electric Off-Road 15 06-26-2008 01:36 PM
lipo question jlfx car audio Electric On-Road 3 06-05-2008 11:26 AM
LiPO question zardoz Electric Off-Road 98 10-25-2007 03:42 PM
Lipo question AZRCaddict Electric Off-Road 3 04-12-2006 02:39 PM
lipo question meetmattveltman Electric Off-Road 8 07-05-2005 06:49 PM
