xxx-s/xxx-4 conversion kit?
Can i convert my xxx-s to a xxx-4?
rally kit perhaps?
The chassis's are different lengths between the two cars. We had someone at our local track try it and it did not work out well. You are better off to just get a XXX4 kit.
i have successfuly built a xxx4 on a xxxs chassis for stock racing, benefits include, lighter weight due to shorter chassis, ability to run no slipper, so the drivetrain is lighter, the car is a little twitchier than a xxx4 but if set up right it actually rotates around corners nicely and carries good speed, a little modification is required to the rear arm mount and the rear shocks have to be run in front of the arms not behind
