Old 08-12-2003, 02:09 PM   #1
LosiFromHell986's Avatar
Send a message via AIM to LosiFromHell986
Unhappy Motor Problem.... Loose End Bell
Around 2 years ago i bought this Trinity Monster of Touring 19x2 for my Rusty w/ a XL1, but i never used it until like 2 weeks ago, never even opened it..... anyways, I threw it in my T3, and I used it for like a week, and now the endbell is loose, like it's about to fall off, and it's really.....glitchy, i guess... Whats wrong??
Oh yeah! and it sounds like its rubbing against something when i go forward, but not backward...?
LosiFromHell986 is offline   Reply With Quote
Old 08-12-2003, 11:11 PM   #2
SlobbaTech's Avatar
There are 2 small chrome phillips head screws that go through plastic only, not the ones that go through the metal brush hoods, on the endbell that hold it to the can. Just tighten them down.
SlobbaTech is offline   Reply With Quote
Old 08-13-2003, 12:06 AM   #3
there are holes, but no screws....put some in? BTW it was brand new , NIP before i put it in
Old 08-13-2003, 04:50 AM   #4
sosidge's Avatar
Looks like you have a sealed can motor. There's probably not much you can do to clamp the endbell back down tight, the endbell may have worn or distorted, or the tabs that hold the endbell on may have got bent. A new motor is probably the best thing.
Old 08-13-2003, 09:25 AM   #5
I disagree. I think Monsters are re-buildable, at least those of the last two years.
Pull it apart. If the locking ring is bent, straighten it; make it flat. You can do this best with a vise. Check the little indentations in the can that hold the locking ring. If they're bent, or flattened, fix 'em. Finally, the end-bell should be held in by two phillips screws that go through it in between the brush hoods. Make sure you've got them both and they both thread up tight into the locking ring. Don't over-tighten those screws, or you'll bend the locking ring and this starts all over....
Engineering Without Fear
www.xfactoryrc.com
www.facebook.com/XFactoryRC
YoungChazz is offline   Reply With Quote
Old 08-13-2003, 12:03 PM   #6
well, pulled it apart last night, the problem is there's no indentations, what could i use to make some?
Jeff
PS the locking ring WAS bent
Old 08-13-2003, 06:53 PM   #7
Now I;m not sure what's going on. Suggest you take it to your LHS & let them see it. I've never seen a motor without tabs for the locking ring to clamp on.
www.xfactoryrc.com
Old 08-14-2003, 10:50 AM   #8
All I can say is I'll take it with me next time i go, thanks for all help! I think I might just get a Speed Gems motor... we'll see, thanks again
Clutch bell problem ERL2004 Nitro On-Road 4 10-31-2007 06:18 AM
Best 19T Fixed End Bell Motor? LosiSuperTruck Electric On-Road 32 10-07-2005 05:28 PM
Mid Screw Coming Loose on HPI 28 Motor SpeedChair Onroad Nitro Engine Zone 2 07-11-2005 10:39 PM
stock motor with v2 end bell any success hailmick Electric On-Road 5 04-24-2005 03:25 AM
Electric Motor Brushes coming loose... Kai_Fuller Electric On-Road 3 05-18-2004 03:32 AM
