Old 06-10-2008, 03:16 AM   #1
Default Motors
I am new to this hobby and I bought a Stampede. It looks like I might need a motor. Any suggestions on which type to get? What do the "turns" mean. how can i know i am getting a powerful one?
anthonystampede is offline   Reply With Quote
Old 06-10-2008, 06:42 AM   #2
Briguy's Avatar
Trader Rating: 125 (100%+)
Send a message via Yahoo to Briguy
the lower number of turns the faster the motor will be . Check with your instructions first because I`m sure there is a limit to how low of a turn you can go with stock ESC .
At Your Service Vinyl Works
Royal R/C & Hobby
Leisure Hours Hobby & Raceway
Briguy is offline   Reply With Quote
Old 06-10-2008, 07:31 AM   #3
RC Dad's Avatar
Trader Rating: 26 (100%+)
Send a message via MSN to RC Dad
Not sure how old it is, but the newer Stampedes came with 12T motors and that's the limit of how few turns your XL5 speed control can handle - the older XL1 speedos were 18T. Any replacement motor with 12 or more turns should work in your truck.
GV2 Pro, XXX4G+, Blitz SCT, CRC GenXL
RC Dad is offline   Reply With Quote
Old 06-10-2008, 08:01 AM   #4
Trader Rating: 23 (100%+)
a checkpoint money 19t
Mike Adamec
TEAM HACK-HACK OR BE HACKED
Trackside Hobbies
not home is offline   Reply With Quote
Old 06-10-2008, 08:34 AM   #5
Jason Pelletier's Avatar
Trader Rating: 33 (100%+)
That would be the ideal choice if you want a reliable fast motor.
Island Raceway & Hobby
Jason Pelletier is offline   Reply With Quote
Old 06-10-2008, 11:52 AM   #6
Crazy Carl's Avatar
Trader Rating: 7 (89%+)
The traxas 12t motors are not based on a 540 motor size
Which means the speedo can only handle a 17t motor (540 size) max
You will be safe with a 19t
Really anything lower and bye bye to your speedo
Crazy Carl is offline   Reply With Quote
Old 06-11-2008, 09:44 AM   #7
i was confused about the number of turns. So I guess you are saying that a 17 turn 540 motor draws more and is faster than a 12 turn 550 motor?
Old 06-11-2008, 09:56 AM   #8
joe of loath's Avatar
550 silver cans draw more than 540 ones, but a stock or modified 540 will draw a huge amount more.
HPI E-Firestorm - Tamiya TA05 racer (carbon chassis, 10.5 brushless etc) - LRP Blast S10 BX - Revo 2.5r truggy conversion (in progress)
joe of loath is offline   Reply With Quote
Old 06-11-2008, 04:13 PM   #9
RC Dad's Avatar
We've successfully put a hot 12T double 540 in a Rustler to replace the 550 cans before and the speedo survived but it did get pretty warm. As a precaution though, I'd probably stick with a higher turn, maybe 15 or above.
Old 06-11-2008, 05:00 PM   #10
d16dcoe45's Avatar
For the type of running you will probably do with a pede and the time you will run add in the weight and the large tires, you will have a hard time gearing low enough for anything less than a good 19 turn. You have to remember though, that a "spec" 19 like the money or the komodo are really race motors. They are fixed at 24 degrees and not really designed to push a heavy monster truck up and down rough hills--I went through a BUNCH of hot motors when I had a Stampede. Get a "mild" machine wound 15-17 turn motor that you can adjust the timing on--it will last longer than a spec 19 or a hot stock motor like a CO27. Get something rebuildable.
Jay Lestingi
Tamiya 419x/Associated TC7.1/Sanwa M12s/Xpert servos
d16dcoe45 is offline   Reply With Quote
Old 06-11-2008, 05:51 PM   #11
ok i went to my local hobby shop where i bought the truck. For $45 bucks he has a 19 turn modified motor (not sure of the brand) he said it would blow away the stock motor. Or for $170 i can upgrade to the whole velinion brushless motor and speed controller. I dont have alot to spend but do you guys think i should go with the velinion?
Old 06-11-2008, 05:52 PM   #12
Briguy's Avatar
Here is a few good motors for you stampede , they have good torque and plenty of power .
http://www.teamtrinity.com/shop/item.asp?item=9254
http://www.teamtrinity.com/shop/item.asp?item=TRI10058
http://www.teamtrinity.com/shop/item.asp?item=EP1121
http://www.teamtrinity.com/shop/item.asp?item=EP1122
There are many other manufactures that have great motors but these are best bang for the $ . Especially that the Intense motors are on sale .
Royal R/C & Hobby
Old 06-11-2008, 05:54 PM   #13
Briguy's Avatar
I`m old school and prefer brushed motors , but you will get more performance , longer runtimes , and less maintenance with brushless .
Royal R/C & Hobby
Old 06-11-2008, 06:13 PM   #14
d16dcoe45's Avatar
If you don't mind spending the money--any of the brushless systems are fine for bashing. Mamba Max. Sidewinder, Novak GTB, LRP Sphere, Velineon, Speed Passion. I would go with one of the cheaper ones. For a Stampede you really can't go wrong with the Velneon. You will have more fun for longer with far less maintenence with a brushless system. That alone will help you enjoy this hobby alot more.
Brushed motors served their purpose well but are going the way of the dodo bird. Brushless/lipo is the future--and for good reason.
Jay Lestingi
Old 06-12-2008, 08:22 AM   #15
RC Dad's Avatar
If you want minimal maintenance and can afford it, go with the Velineon system. We haven't run them - I'm still a brushed motor guy - but many run them at our track and really like them. They all have lots of top end but not much grunt so I'd suggest gearing it way down for long-life bashing, especially with those big tire's on the stampede.
Trinity Co27 Monster Stock Pro Motors & Reedy Neo 2* BL Motors For Sale Leodis R/C Items: For Sale/Trade 17 05-11-2007 06:03 PM
GM Brusless ESC & Motors, LRP Charger, MM Motor Master, Yokomo Motors tones Australia For Sale/Trade 5 05-08-2007 07:22 PM
MOTORS MOTORS MOTORS EPIC C2,INTEGY BLUE ATLAS 19,AN MORE DENNIS STORTI R/C Items: For Sale/Trade 18 01-06-2007 09:44 AM
Mod Motors, Stock Motors, Rubber Tires and a Novak Syns. Module Team Speedy R/C Items: For Sale/Trade 1 07-13-2006 07:28 PM
stock motors . mod motors - feedback needed Babylou Electric Off-Road 4 05-07-2004 05:00 PM
