Old 06-08-2008, 03:08 PM   #1
TheBigEasy's Avatar
Default Tuning a Mamba. Help please.
I recently put the Mamba Max 7700Kv system in my slash. It is a bit too much power. I have heard you can turn the amount of volts or something that the esc pushes to the motor. How would i go about doing this? At half throttle right now i am way over shooting any jump on the dirt track i ride at. I know this motor is too much to begin with, but its what i got right now. Thank you for any help with this.
TheBigEasy is offline   Reply With Quote
Old 06-08-2008, 04:10 PM   #2
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Hook onto the Castle link and turn the punch control down to like 70% and if that is still too much you can turn it down lower or higher as needed.
ST Racing Concepts (STRC)
Old 06-08-2008, 04:24 PM   #3
TheBigEasy's Avatar
Old 06-08-2008, 04:28 PM   #4
TheBigEasy's Avatar
What is voltage cutoff? And should i use it?
Old 06-08-2008, 04:31 PM   #5
TheBigEasy's Avatar
I set the cutoff to 6.0volts, thats what the guide suggested for my 2 cell lipo. These new rc cars are pretty invovled.
Old 06-08-2008, 04:36 PM   #6
wyd
Tech Legend
wyd's Avatar
That will be fine. Unless you run alot more than a standard race at your track you will never get to 6 volts in a standard race.
Old 06-08-2008, 04:37 PM   #7
Voltage cut-off:
As the battery drains, the voltage goes down also. If it goes too low it completely screws the battery. Same goes for NiMH cells, but i've heard there is little slack when it comes to LiPo's
JR007 is offline   Reply With Quote
Old 06-08-2008, 04:51 PM   #8
TheBigEasy's Avatar
Sweet, i have a totally new setup to try tomarrow after work at the track. I'm gonna bring my wifes laptop with me if i need to change anything. I set the throttle to 70% w/o reverse, and 6volt cutoff, i think thats all i changed.
Old 06-08-2008, 06:31 PM   #9
Trader Rating: 53 (100%+)
Send a message via AIM to nv529
if you have digital fm or 2.4ghz radio you can turn down the EPA to about 70% also your finger is by far the best speed control option try not to use so much throttle your radio isn't a ON or off switch all the bells wistles in the world can never replace a good throttle finger honestly watch any good driver not their car but his throttle finger its a smoooth roll on and off the power motion.
Nick Vasquez
Tekin | Reilly Paint | Dirt Burner Racing | RC Clubhouse| Washtenaw RC Raceway | TARCAR | The Track
nv529 is offline   Reply With Quote
Old 06-08-2008, 08:58 PM   #10
Any suggestions for arming time setting?
vtec_chump is offline   Reply With Quote
Old 06-08-2008, 09:11 PM   #11
carbon madness's Avatar
If you are using FM or AM then leave it where it is at, but if you are useing spek. then you can set it up to 5 sec. to allow your radio system time to link up before you can run the car.
All that setting does is allow your radio to link up before you can use the system.
マイクル ユージャック
*Team CFX Racing**Evil 3 Paint Works*
carbon madness is offline   Reply With Quote
MAMBA MAX TUNING !!! AlphaDOG Electric Off-Road 6 06-23-2008 03:14 AM
Tuning Class..any SIFU (klang valley) offer engine tuning class??.. azmin Malaysian R/C Racers 17 06-20-2008 10:42 PM
Engine Tuning 101 (General Tuning) Kemorc Onroad Nitro Engine Zone 41 11-19-2007 07:04 PM
beginner questions re: car tuning and motor tuning! Captjono Rookie Zone 5 02-19-2005 12:01 PM
beginners question re: car tuning and motor tuning! Captjono Electric On-Road 5 02-19-2005 03:01 AM
