Old 08-04-2003, 12:19 PM   #1
Angry mt final diff gear
i have a hpi nitro mt ive gone thru 5 pairs of stock final diff gears
in the rear end they last about a half hour the last one i put in
i was out of grease so i ran it dry it lasted about an hour.
when i take it apart the only gear that is stripped is the 13tooth
gear the the other gear (38tooth) is fine. there is also a fine black
powder in the gear box. help me.
flysopen is offline   Reply With Quote
Old 08-05-2003, 07:14 PM   #2
corvettecrazy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to corvettecrazy
are you running a just RWD set up or are you running 4wd??
corvettecrazy is offline   Reply With Quote
Old 08-06-2003, 01:02 PM   #3
its a 4x4 the front one ive never had a problem with ,but the rear one doesnt last one day ,i even went to a 14tooth onthe bellgear
it had a 12tooth stock ,to take some torque on the bottom end
also tried running no grease, no luck
Old 08-06-2003, 04:01 PM   #4
i wouldn't expect no greese to help that should just make it wear faster.
so you are still running 4wd? that was my only thought I really dont know what to say or reccomend now.
Old 08-07-2003, 10:06 PM   #5
no have to run 4wd it wont run very fast if i dont i put a hardened diff in it that so far has helped.
Square diff lock hub and gear diff oil for TT-01/R/D Drift Demon Australia For Sale/Trade 0 12-12-2006 10:34 PM
final gear ratio for sprint 2??? martytx1234 Rookie Zone 3 04-28-2006 02:39 PM
Final Gear Ratio for Sprint 2??? martytx1234 Electric On-Road 0 04-27-2006 10:43 AM
front lock diff vs gear diff rhed Nitro On-Road 4 11-29-2005 02:20 PM
Final gear ratio for different motor discus18 Electric On-Road 3 10-08-2003 01:49 AM
