largest lipo that will fit in a b4?
Like nitrotruckn said, the Maxamps 8000Mah will fit, not the 1/8th scale pack, but the regular 8000 pack. Its a little taller than a standard lipo pack, but you can run longer screws through the battery strap to make it work. I have my B4/T4 set-up for long runs using this battery.
maybe the 10,000mah will fit with the longer T4 chassis installed on your B4?
Flightpower 4900 20c soft packs will fit as well, just eliminate the foam spacer and it will be fine. I assume the 5000 25c flightpower packs will work as well
If you have a esc and motor that can handle it, a 3 cell will give you more runtime since more volts reduce the amp draw. Just would need to drop a few pinions so as to not have an overly insane speed.
Not much though, the 3 cell battery in the same space as a 2 cell will have to be made with smaller lower capacity cells. So while the amp draw does go down, there are also fewer amp hours available. A slight increase from an increase in efficiency, but not all that much I suspect. Possibly less runtime with the same motor even geared down, as it would accelerate harder. A milder motor would need to be used to take best advantage of 3 cells for runtime with a given performance level.
