Old 05-20-2008, 03:07 AM   #1
Trader Rating: 22 (100%+)
Default Tamiya DF03 spur/pinion gears
I have am thinking of buying a Tamiya DF03 dark impact from a mate. The spur/pinion gears are very noisy. I have heard that the gears on these are
48p but not standard 48. I was told that Tamiya have their own 48p with a slightly different profile that doesn't quite mesh with other 48 gears which makes them very noisy. Is this right? Please help.
Terry
Is your car slow..Xray it!.......FK05, M18, M18t
RexX
Assoc...T3,T4, B4
Team Ash is offline   Reply With Quote
Old 05-20-2008, 03:22 AM   #2
bender's Avatar
The gears are 0.5 module gears, and they work fine.
It is usually when people try to use 48dp pinions with the kit spur gear that you get the noise.
0.5 pinions are hard to find though - but some HK shops sell the Tamiya ones, albeit only a limited range.
Kawada make an adapter which allows you to run normal 48dp spurs with the Tamiya Slipper clutch.
Jason W
FIR#2 - "You can't buy this much talent"
Durango Dex410 - Schumacher Cougar SV - Top Photon
bender is offline   Reply With Quote
Old 05-20-2008, 03:28 AM   #3
Default DF03
Thanks for the help. I have got standard 48p pinion on it so I will try to get the adaptor. A bit less noise would be good.
Terry
RexX
Assoc...T3,T4, B4
Old 05-20-2008, 07:44 AM   #4
oople's Avatar
adaptor huh. from my weak memory you can very easily put a B4 spur and pads on the Tamiya df03 slipper no problems at all and no adaptor needed. Ream the inner hole on the spur slowly - a little at a time from either side until it just slips over. There is no problem with wobble since it is clamped by the pads - the centre hole only needs to keep it centered. Takes 30 seconds.
Jimmy Storey - www.oople.com
oople is offline   Reply With Quote
WTB: Pinion and spur gears mattmacf R/C Items: Wanted to Buy 7 07-17-2008 12:38 PM
Spur & Pinion Gears porschejim911 R/C Items: For Sale/Trade 4 04-22-2008 08:21 PM
WTB: Rc10t4 Spur Gears, And Pinion Gears Associated-08 R/C Items: Wanted to Buy 0 03-10-2008 09:19 PM
Lot of 14 Pinion Gears, 2 Pinion Holders, and 3 Spur Gears (64 Pitch) MyRCTrader R/C Items: For Sale/Trade 4 02-04-2008 07:08 AM
WTB Pinion & Spur Gears for tamiya TA05 Redwings R/C Items: Wanted to Buy 0 01-29-2007 08:54 AM
