Old 08-01-2003, 04:11 PM   #1
Default rc10gt idleing
when the wheels are off the ground in idle they spin. is this correct? do you think the weight of the car will keep it steady when it is on the ground? if so what should i do to fix it?
thanks
gasnewb!!!! is offline   Reply With Quote
Old 08-01-2003, 08:37 PM   #2
an ideal idle would be no tire spin with no brakes applied or dialed in. If the tires move then the clutch is engaging and all you are doing is wearing down your shoes. try to get it to not spin the tires even if a little (I mean a little) bit of throttle is applied.
jswinkos is offline   Reply With Quote
Old 08-02-2003, 09:20 AM   #3
thanks for the advice but how do i do that?
thanks, jeff
Old 08-02-2003, 09:51 AM   #4
if the idle starts to die after just a few seconds, then lean out the low end needle till it is steady. then readjust the idle set screw. you may have to richen the high end needle. go to www.parisracing.com under tips for more answers
Old 08-02-2003, 06:06 PM   #5
Deven's Avatar
Send a message via AIM to Deven
Also make sure your clutch shoes are installed properly... the end with the hole should be rotating the way the engine does.
Improperly installed shoes will most likely cause any engine to die when placed on the ground.
Deven is offline   Reply With Quote
FS/kanai 2/rc10gt arr/mugen mst-1 w/parts/rc10gt roller mint/recievers/servos thedoc329 R/C Items: For Sale/Trade 9 02-02-2008 04:09 AM
rc10gt ca-tn R/C Items: For Sale/Trade 3 04-29-2005 02:11 PM
f/t or f/s rc10gt bigbass R/C Items: For Sale/Trade 0 04-25-2005 06:43 PM
RC10 GT starting probs/idleing probs Smoke21 Electric Off-Road 3 07-13-2004 11:03 PM
RC10GT with (new)CVR biker R/C Items: For Sale/Trade 12 10-11-2003 09:53 PM
