Old 07-31-2003, 12:31 PM   #1
Default O.S. .15 problem!!!!
I just started my .15 O.S. CV-RX and it starts fine but after about 20 seconds it starts to rev higher and higher. and then when i go to pinch the fuel hose it revs higher and then shuts off.
please help me!!!!!
gasnewb!!!! is offline   Reply With Quote
Old 07-31-2003, 07:05 PM   #2
Send a message via Yahoo to ray v.
I would check your needel settings on both top an bottem end. Look at your carb. Make sure that the Air Filter is cleen, make sure there is nothing in the carb, an that it opens an closes smothly. Also make srue your Idel is set coretly.
ray v. is offline   Reply With Quote
Old 08-01-2003, 01:22 AM   #3
WheelNut's Avatar
Send a message via MSN to WheelNut
Check that glow plug also. And make sure there are no screws loose or anything like that on the enige.
WheelNut is offline   Reply With Quote
Old 08-01-2003, 07:36 AM   #4
in the manual it says to turn the needle valve 2 turns from closed. do they mean 2 full turns or 2 half turns?
thanks, jeff
Old 08-01-2003, 05:03 PM   #5
2 full turns and like te other guy said check every screw on the motor even the head bolts i bought a brand new motor and the head bolts were loose and the carb bolt that held it to the motor was loose.
flysopen is offline   Reply With Quote
ESC PROBLEM ghj1997 Electric Off-Road 13 06-04-2008 08:38 AM
Problem RaceANissan616 Nitro On-Road 20 07-23-2006 09:07 PM
KO PRO PO VSF-1 PROBLEM mazmo Australian Racing 4 07-24-2005 07:38 AM
New to R/C and I have a bit of a problem ZeeBMaN Rookie Zone 6 05-15-2003 05:08 AM
