Brushless motor max temp >
Old 05-09-2008, 07:49 PM
GSM Storm's Avatar
Trader Rating: 114 (100%+)
Default Brushless motor max temp
Hi all
What is the max temp that you should run brushless motors at.
Regards
Gary
GSM Storm is offline
Old 05-09-2008, 09:06 PM
depends on the manufacturer but the range I have seen is between 160-200F . Castle is the only one to my knowledge that recommends under 200. I think Novak likes to see no more than 170. Not sure about the others. Hope this helps.
JLinney is offline
Old 05-10-2008, 12:30 AM
glassdoctor's Avatar
Common thought is that Neo mags ore ok up to 200*F... may start to weaken at like 220+ range. Depends on who you ask.
Problem is you don't know exactly how hot the rotor is in there...
My rule of thumb is 180*... over that be careful and definitely try to keep it under 200*.
I had a Feigao come off the track at 300* the other day. Needless to say it's a paper weight now.
glassdoctor is offline
Old 05-10-2008, 12:46 AM
GSM Storm's Avatar
Thanks guys
the motors are Novak and LRP, will give it a try tomorrow and see how it goes.
Regards
Gary
Old 07-14-2011, 01:03 PM
what about temps on the ESC`s?
postie90 is offline
Old 07-14-2011, 01:35 PM
How did you manage that?
Wattser93 is offline
Old 07-14-2011, 02:40 PM
GoatsnBros's Avatar
Trader Rating: 56 (100%+)
When I start to see 175-180 I try to take steps to cool it down.
Buddy took his truck off the track and motor was at 236. He was pulling it to runs something else (obviously) and we took it apart and the there were bits of solder that had slung itself inside of the front cover. opps
GoatsnBros is offline
Old 07-16-2011, 10:23 AM
Castle techs told me in a phone call once not to go above about 180 because 1. the resins used to hold things together inside the motor start to brake down between 220-230deg. 2. What you temp on the outside of the can can be up to 50deg hotter in the core. Hence keeping it below 180 ensures you are running it cooler than those resins can melt and fail.
jasonwipf is offline
Old 07-16-2011, 06:35 PM
Mr RCTech's Avatar
+1
Power begins to fall off at 160+ degrees.
For club racing I keep mine under 160.
Also, I just recharge my rotor.
Mr RCTech is offline
