Old 05-06-2008, 04:46 PM   #1
Send a message via AIM to playboy Send a message via Skype™ to playboy
Questions?? Battery fried?????
i was driving my car and everything jusr fried up in it and i want to know if the battery is still good. it is a 4200 intelect slingshot. it was warm after everything gor fried but is it stil. ok to use????????
playboy is offline   Reply With Quote
Old 05-06-2008, 05:20 PM   #2
Suspended
try fixing it just try hard
pete123 is offline   Reply With Quote
Old 05-06-2008, 07:49 PM   #3
beast95451's Avatar
Lemme guess..... Novak GTB?
beast95451 is offline   Reply With Quote
Old 05-06-2008, 08:41 PM   #4
hahah no it was the LRP quantum 2
it fried my speed controller, reciever, servo, and personal transponder!!!!!!
is the battery ok???
Old 05-06-2008, 09:03 PM   #5
sport10's Avatar
Are you sure that it was not the battery that fried the components. This is very unusual. I would not trust the battery if it was me.
Hot Bodies VE8 w/ RX8-1900 combo
Associated B44
Associated B6
Associated TC7.1
Durango DESC410V2 Pro
sport10 is offline   Reply With Quote
Old 05-06-2008, 09:18 PM   #6
It would be very hard pressed for the battery to suddenly cause this damage. You can inspect the shrink to see if any metal is showing other than the buttons on top and bottom of each cell. You can also run a voltmeter across the cells to make sure they are the same. As long as these things are good, run it. A 7.2v pack cannot suddenly combust all of your electronics, unless you shorted it out.
-Ryan Dunford
Horizon Hobby Spektrum Product Manager
TLR--Spektrum--Horizon Hobby--Tekin--Venom--Pro-Line--Sticky Kicks--Bradley FLD--ImagineIt Graphics--Casper-RC.com
TLR 22 3.0, TLR 22T 2.0, TLR 22SCT 2.0, TLR TEN-SCTE 2.0, TLR 8ight-E 4.0, DX6R
hacker07 is offline   Reply With Quote
Old 05-07-2008, 05:18 AM   #7
Trader Rating: 16 (94%+)
BSS07 is offline   Reply With Quote
Old 05-07-2008, 06:33 AM   #8
OG RC 10T's Avatar
Trader Rating: 41 (100%+)
Thats a tough one. I would say if they all fried, but the battery was ok, I would think it would have been the reciever to go first, possibly.
The reviever is the only thing that all of your electronics have in common, because they are all pluged in to it at the same time.
Check the battery with a volt meter to be sure.
Did you drive through water or a wet surface?
Original RC 10T, T4, RC8Te, Tekin RX8. Losi Ten SCTE, Slash 4x4.
OG RC 10T is offline   Reply With Quote
Old 05-07-2008, 08:23 AM   #9
Casper's Avatar
Trader Rating: 34 (100%+)
Actually if the ESC goes and the BEC fails it can then go after everything else. The reciever and PT and servo may not like the 8-9V the battery would pass through as well as the amperage. The ESC BEC system is supposed to regulate the voltage and amperage the receiver gets and if that fails the rest of your stuff is at risk.
Rarely is this an issue with the battery. Like Hacker said check the cells with a volt meter. As long as they are all similar in voltage the battery should be fine.
TLR/Losi Team Driver
TLR/Losi | Tekin | DE Racing | Spektrum | Exotek | JBRL | Kolor Koncepts | OC/RC |Sticky Kicks | Imagine It Graphics | Casper-RC.com
TLR 22 4.0 SR, TLR 22T 4.0, TLR 22-4 2.0, Spektrum DX6R
WWW.CASPER-RC.COM TLR and Tekin setups
Casper is offline   Reply With Quote
Old 05-07-2008, 08:27 PM   #10
ok well i just looked at the voltmeter and it was fine and no metal was exposed so i pluged it in my gtb and it worked fine but thank you for all you help
thanks
peter
Fried my GTB STRINGCHEESE Radio and Electronics 3 05-14-2008 05:35 PM
fried ESC? sportsracer-5 Electric On-Road 3 05-16-2007 04:43 AM
esc fried? MK_Arbiter Electric On-Road 13 11-26-2006 06:08 AM
How to Tell if ESC is FRIED!? AWK Electric On-Road 19 09-20-2006 03:00 PM
New Intellect 4200mAH battery pack fried my motor envirojay Electric On-Road 43 01-17-2006 12:45 PM
