Old 05-05-2008, 05:16 PM   #1
Default Balancing harness=Orion lipo BAtt./Core RC charger
Does anyone have a wiring set up for balancing while using a Core-RC charger to charge Orion Lipos? It would also apply for any 2 cell that does not have a balancing lead.
Pics would be helpful. Thank you.
derekride is offline   Reply With Quote
Old 05-14-2008, 12:46 PM   #2
stitchy's Avatar
anyone?
Speedtechhobbies.com
stitchy is offline   Reply With Quote
Old 05-14-2008, 01:08 PM   #3
abailey21's Avatar
Trader Rating: 36 (100%+)
check with www.allerc.com for a possible adapter
K.C.C.O.
abailey21 is offline   Reply With Quote
Old 08-06-2008, 12:28 PM   #4
stitchy's Avatar
Thanks Adam, I checked on their site, but they mostly have harnesses for the Hyperion charger. I sent an inquiry and will see what they say.
I'd be happy with another 2S balancing harness just like the one the Core chargers come with. Is there any way I can buy just that one part?
Old 08-06-2008, 12:33 PM   #5
Here it is: http://www.nexusracing.com/newsdesk_...28f9e96e4df315
Bye!
Fastfreddy74 is offline   Reply With Quote
Old 08-06-2008, 12:42 PM   #6
stitchy's Avatar
Thanks freddy, that was the article that inspired me to look for an extra connector to make my own harness. But thanks anyways!
Old 08-06-2008, 06:21 PM   #7
stitchy's Avatar
I found a supplier for the connectors, I only wish there was something pre-built.
Here you go, DIYers!
http://search.digikey.com/scripts/Dk...me=455-1612-ND
http://search.digikey.com/scripts/dk...me=455-1001-ND
http://search.digikey.com/scripts/dk...=455-1042-1-ND
Old 08-07-2008, 12:42 AM   #8
stitchy's Avatar
After doing a lot of research, I've come to the conclusions that given the Core UDC-20 charger and balancing harness it comes with:
The Core charger and the harness connector that plugs INTO the charger are JST-XH.
The Core 5000 lipo battery balancing connector and the harness connector that plugs INTO the battery are JST-EH
I was thinking, if all the plugs are JST-EH, then why can't you plug the battery into the charger directly without the harness the UDC-20 comes with? (You can kinda jam it in there, but it's not a perfect, direct fit)
So, for anyone wanting to make the above Nexusracing harness without hacking up the harness that comes with the Core UDC-20 charger, you need the receptacle (female) end of a JST-XH connector.
On a separate note, the Reedy 5000 lipo has a JST-XH connector so it'll just fit into the side of the charger without any harnesses at all (which is what I think Core should've done in the first place with their own batteries).
balancing orion 3600 lipo with a blinky David Wall Radio and Electronics 5 12-19-2008 08:52 PM
Balancing on the CORE UDC-20 Charger Hebiki Radio and Electronics 2 08-11-2008 04:20 PM
Balancing Lipos on the CORE UDC-20 Charger Hebiki Electric On-Road 9 08-11-2008 04:01 PM
Lipo charger for Orion BAtt. derekride Electric Off-Road 10 05-04-2008 11:04 PM
IS IT POSSIBLE TO INSTALL A BALANCING HARNESS meronr Radio and Electronics 7 02-26-2008 05:32 AM
