Old 05-03-2008, 06:58 PM   #16
morris's Avatar
Trader Rating: 40 (100%+)
Originally Posted by tmail55 View Post
Losi Springs
1.15" 7.6 White
1.15" 8.6 Orange
1.15" 9.6 Yellow
1.15" 10.6 Pink
1.15" 11.6 Red
1.15" 12.6 Silver
1.15" 14.6 Blue
1.15" 17.5 Dark Green
2" 2.5 Red
2" 2.9 Orange
2" 3.2 Silver
2" 3.2 Green
2" 3.8 Blue
2" 4.1 Black
2.75" 1.8 White
2.75" 2.0 Yellow
2.75" 2.3 Pink
2.75" 2.6 Red
2.75" 2.9 Orange
2.75" 3.4 Silver
2.75" 3.7 Green
2.75" 4.1 Blue
wow guess you learn something everyday.i was under the impression that all losi springs were from softest to stiffest in the order as you have it under the 2.75"....i didnt know they changed.....huh...?
as for you getting traction....bigger pin tire would help....also keep in mind where the shocks are mounted...having them mounted in the back straight up and down as much as you can will generate more forward traction.
same as the front the more up/down you have them will generate more steering.
30 oil in front and rear is a good oil that is nuetral from track to tarck...prolly to soft for the carpet thing...but good start for the dirt....chris wolfson in here is good with the losi xxxt set-ups...even when i was stumped he showed me somethings...so maybe if you have more problems you can pm him with some helpo....he is a nice guy and will help out.
hope this helps,
matt
AE/VIPER/XPERT/DIRTCHEAPRC.COM/JCONCEPTS
A big thx to all the tracks that I race at:cause if it wasnt for these guys..we wouldnt have a place to race our r/c cars!!!
morris is offline   Reply With Quote
Old 05-03-2008, 08:28 PM   #17
Setups
Spring Chart (PDF)
Arn0 is offline   Reply With Quote
Old 05-04-2008, 09:45 AM   #18
THANKS everyone, our practice session yesterday after some changes on his truck helped alot, Today is start of a points series, and hopefullly we will run good.
HAKYLIKESRDAD is offline   Reply With Quote
Old 05-05-2008, 07:58 AM   #19
We had a better day at the track. After 3 rounds of Qualifiers he was 6th of 14. He made the A-main, After 4min. he got ran over by a LAPPED TRUCK and broke a A-arm. !#$&%! END OF RACEDAY!!!!!
BY THE WAY HE WAS RUNNING THIRD WHEN WRECKED
Old 05-05-2008, 08:34 AM   #20
Losi Springs
1.15" 7.6 White
1.15" 8.6 Orange
1.15" 9.6 Yellow
1.15" 10.6 Pink
1.15" 11.6 Red
1.15" 12.6 Silver
1.15" 14.6 Blue
2" 2.5 Red
2" 2.9 Orange
2" 3.2 Silver
2" 3.2 Green <<< wrong rate it's 3.5
2" 3.8 Blue
2" 4.1 Black
2.75" 1.8 White
2.75" 2.0 Yellow
2.75" 2.3 Pink
2.75" 2.6 Red
2.75" 2.9 Orange
2.75" 3.4 Silver
2.75" 3.7 Green
2.75" 4.1 Blue
pink through blue are 2.5" not 2.75" t
Team Associated, Reedy, LRP, Factory Team, Jconcepts, BFastRc, Darkside Designs, CRCRC.com, Dirt Burner Racing
DanGriffin is offline   Reply With Quote
Old 05-05-2008, 11:48 AM   #21
Trader Rating: 35 (100%+)
Awesome! It sounds like some of those settings really helped you out! If you want the RC setup bible, check out this link. It is a lot of reading, but all worth it.
http://users.pandora.be/elvo/
High Desert Raceplace, Grand Jct CO, Sanwa Exzes Plus Stick Radio, Spektrum,Thunderpower 230g, Modified Tri-Nut Novak GTB2, Ballistic 4.5t 550, 5.83lb SCTE Ten, Novak Sentry Brushless Dyno, Crossweight Setup Station, Junsi 20A power supply Icharger 20A Charger,TP610C, 22B, Novak Edge, Novak 13.5, SC10, Havoc Pro SC XDrive, Ballistic 17.5 Matthew Joseph Cordova
mattnin is offline   Reply With Quote
Old 05-05-2008, 12:53 PM   #22
Man that article has a huge amount of info in it. I will be using it a little at a time so we can determine what helps and what doesn't. Changing 1 thing at a time is the way to go, but now we have alot of info to draw from.THANKS ALL FOR YOUR HELP!!!! I will keep everyone posted on how it's going. Also any other suggeestions would be WELCOMED!!!
Old 05-05-2008, 01:07 PM   #23
You are right, changing one thing at a time is the best way.
Also, another thing I found that really helped me out a lot is where you marshal in a race. If you are consistently having trouble in one corner, turn or section of a racetrack, marshal that section. You will get a different perspective and possibly help you out when you are on the drivers stand.
Spring Rates Boultspeed Electric On-Road 0 05-14-2007 12:52 PM
Spring Rates ford_racing Electric On-Road 3 01-27-2006 09:42 PM
Spring rates? Downforce Electric On-Road 0 02-29-2004 07:49 PM
Spring Rates omalley Electric On-Road 1 04-21-2003 02:39 PM
HPI spring rates??? DJ_GenR8 Electric On-Road 3 05-29-2002 04:54 PM
