Losi xxx-4
Old 09-14-2007, 06:54 AM
  #1396
dirtdustingdavo's Avatar
Trader Rating: 18 (100%+)
Can any one tell me where I might get alloy spindle's and spindle carrier's?
I found the graphite one's seem to break quite easily.
dirtdustingdavo is offline
Old 09-16-2007, 03:29 AM
  #1397
Any tips on getting more rear traction?
Old 09-16-2007, 10:04 AM
  #1398
Alltapdout's Avatar
Tires
Alltapdout is offline
Old 09-17-2007, 02:47 AM
  #1399
Originally Posted by Alltapdout
Tires
Um yea thats obviously the fist thing to look at, which I have done (im using the same as the fastest driver at my track) so what is next?
Old 09-17-2007, 06:40 AM
  #1400
Alltapdout's Avatar
Default 4wd drifter
What kinda tires are they, I'm not a follower so i usually don't run what the "fast" guy is running I run what works for me and my driving senerio!
Personally I like bowties, but there are other tires that will give more rear bite. Adjusting shock position will also change some of the rear slidding out issue.
When is your ride loosing traction? out of turns? into turns?? just plan crazy on the straights? have you made any camber adjustments? good luck!
Old 09-18-2007, 09:11 PM
  #1401
Any recomendations on screw sets? I need to replace the screws on mine. I had saw a set on ebay but now I can't find the store. Any recommendations ? Links or parts numbers would be great.Thanks
tonyking73 is offline
Old 09-18-2007, 09:35 PM
  #1402
http://tonysscrews.com/product.sc?ca...&productId=235
gatermaxx is offline
Old 09-19-2007, 01:06 AM
  #1403
It seems to break away as I come out of loose corners. I'm going to have a look at my camber settings and do some testing this weekend.
Old 09-21-2007, 04:24 AM
  #1404
sylv456's Avatar
Anybody got Mike Truhe's basic setup?
sylv456 is offline
Old 09-29-2007, 05:15 PM
  #1405
Would a B4 titanium turnbuckle kit fit a xxx4? Im looking to do a color scheme . Anybody know of any other companies that sell different color titanium turnbuckles? Thanks
Old 09-29-2007, 09:07 PM
  #1406
jrr102486's Avatar
i think that the b4's are longer. you could always anodize them yourself. then you can do any color scheme you want. as for any other companies making the colored ones im not sure.
jrr102486 is offline
Old 09-29-2007, 09:40 PM
  #1407
The first things I would try are:
Shorter rear link (probably going more "out" on the tower)
Shorter wheelbase
More front caster
DanGriffin is offline
Old 09-30-2007, 05:11 AM
  #1408
Shorter wheelbase
More front caster
I hadn't considered a shorter wheel base. What benefits will each of these changes give me?
Old 09-30-2007, 06:47 AM
  #1409
Registered User
Dasupacat1's Avatar
Trader Rating: 25 (96%+)
I would not go longer wheelbase. The car is a handful as is. Try softer springs or lighter oil in back. Check camber. Top of shock in. Batt back. Stiffer setup up front.
Dasupacat1 is offline
Old 09-30-2007, 04:25 PM
  #1410
I'm already running a long wheel base, so that will be the first thing I change. Ill have to do some more trial and era testing. If I go a larger pinion will that allow me to go a tad slower out of a corner, thus reducing the amount of wheel spin on exit?
