Losi xxx-4
#1366
you talking xx-4 or xxx-4? and what part? look at the exploded views, they are different. i have both of them and parts are not the same.
#1371
I just broke my first front shock tower... Does anybody recommend a third party replacement part (carbon fiber?) or is the Losi part the good one to ride?
#1372
just double up on the front shock tower. it makes it super stong. just need dome longer bolts. i actually switched to the non-graphite one and i havent broken one since.
#1375
whatever man, id rather run that thing as wide as possible. i would maybe change the rear sway bar before i start making it narrower. seems to me make it narrower=making it tip easier.
#1377
i got the Graphite plus about 2 years ago and only driven it a few times broke a belt and blew up my electric motor now its running again with a team kiwk 19t stocker novak gts and spectrum servo and radio
#1378
Registered User
Well I wanted to try 1 deg. rear hubs. So I got the #9807 like it says in the option parts list in the back of the parts page. When I got the hubs there was only one hole for the hinge pin
. The part says XXX, T, NT. Is there another hub out there that has the VLA? I looked in the BK2 parts but didn't see an option. What is everybody using? I could use these hubs but it will be a short arms setup.
#1379
You would have to use the narrow VLA option on the arm with those hubs. I'm not sure if there were any VLA hubs with different toe options.
