Losi xxx-4
Old 04-20-2007, 01:08 AM
  #1186
jrr102486's Avatar
where can i find some aluminum spindles and carriers? i keep breaking mine and it sux. i have a lot of extra's if anyone is interested in swapping or buying off me. that and a front diff cover as well. i always break that on the 2 op screw mounts and the bottom ones on the chassis. any help would be great thanx.
jrr102486 is offline
Old 04-20-2007, 02:11 AM
  #1187
Drift_Buggy's Avatar
Trader Rating: 22 (100%+)
http://www.amainraceway.com/ctlgoffroad.htm
Cheers
Drift_Buggy is offline
Old 04-20-2007, 06:52 AM
  #1188
sport10's Avatar
Originally Posted by K_King
I dont know anything about 4WDs LOL other than they push like mad since all 4 tires always spin. Maybe talk to Golatka or Billy, they have XXX 4s.
Yep, you know nothing about 4wd's then. Not all 4wd buggies push like mad. Losi's XX-4 and Xfactory's X-5 has a ton of steering. The rear motor placement of the XXX-4 makes it push some, it is not the fact it is 4wd. This can be changed by going to a oneway diff in the front though.
sport10 is offline
Old 04-20-2007, 07:02 PM
  #1189
GymBeam's Avatar
hi
i bought a xxx-4 2nd hand,
can u put a center one-way in this car? what part do i need? thanks
GymBeam is offline
Old 04-22-2007, 07:22 AM
  #1190
Alltapdout's Avatar
Yes, you can put a xxx-s 1-way in the diff, others could probably tell you better than I. I think it just comes in a kit. #losa3245. I dont run one because i didn't think it was going to help my racing abilitys I'm not even sure what they would help...(If someone could fill me in I would greatly appreciate it!).
*On another note* Has any one seen the front alum inner pivot mounts? Did they quite making these?
Peace.
Alltapdout is offline
Old 04-22-2007, 07:36 AM
  #1191
sport10's Avatar
I do not think they stop making the inner pivot mounts. Frankly, I would not use them. If you use aluminum on the outside pivot brace and inside pivot mounts then the only thing that will break is the Diff cover or chassis. It is alot easier to just replace the graphite inner pivot mounts and use only a aluminum pivot brace. It is still plenty strong with this setup.
The XXX-4 will not accept a center oneway due to the single belt drivetrain. A dual belt would be needed for this. Instead you use a one-way diff in place of the front diff. A oneway diff allows the front wheels to disengage under braking and rolling. This greatly increases the intial turn-in of the car and allows rear wheel breaking to help the car pivot better in the turns. It is not easier to drive but faster on some tracks than full time 4wd and a regular diff.
sport10 is offline
Old 04-22-2007, 05:25 PM
  #1192
losi09's Avatar
I would like to get some hop up parts for my xxx-4wd and I was wondering if anybody here knows were I can buy them and what hop up parts for the car I should get?
losi09 is offline
Old 04-23-2007, 12:56 AM
  #1193
m_perkins's Avatar
cole you never told me you had a xxx4 when did you get it . when are you coming down to FHR whenever you do bring it im getting mine running pretty soon just bought it used I already love it
m_perkins is offline
Old 04-23-2007, 01:00 AM
  #1194
m_perkins's Avatar
do you have a xx-4 or a xxx-4 the xxx-4 should come with all the hopups unless they made a plastic car RTR which I dont think they did. if you can posts some pics
Old 04-23-2007, 02:34 AM
  #1195
What are you after?
Amain make aluminum carriers
Losi make aluminum front and rear aluminum inner and outer pivot points
http://www.losipartshouse.com
You can also get a better belt hold down
http://www.iq-tuning.ch/en/belt.html
And Xtreme Racing make colored carbon parts for the xxx-4
http://www.xtremercracing.com/XXX_4.cfm
Cheers
Old 04-23-2007, 04:08 AM
  #1196
GymBeam's Avatar
anyone find that boiling the plastic parts make them stronger? the losi plastics seems a little brittle
GymBeam is offline
Old 04-23-2007, 05:19 PM
  #1197
losi09's Avatar
I thougth I told u that I had one guss not, anyways I have had it for a long time know. I have not raced yet either one of not had the time and whatever race track I go to does not have enougth 4wd's to have a class or there on no 4wd's to race. I have the xxx-4 and I thougth u were going to get a BJ4? I am not sure when I am coming down to FHR but I will make sure that I will be there for when the track closes orther then that I am not sure when I am going to be able to make it down.
losi09 is offline
Old 04-23-2007, 05:20 PM
  #1198
losi09's Avatar
Originally Posted by Drift_Buggy
What are you after?
Cheers
Yeah thougths are the parts that I have been looking for but could not find them agian thanks. Is that the only hop up parts they sale for the xxx-4?
losi09 is offline
Old 04-23-2007, 07:11 PM
  #1199
m_perkins's Avatar
cole we are actually getting a big turnout now down here so yea. also the 4wd class theres about six of us now runnung 4wd
Old 04-23-2007, 07:28 PM
  #1200
losi09's Avatar
Thats good that you geting a good turn out down there know and that u are geting a 4wd buggy class going know. Know I am going to have to get my 4wd buggy going I have all the things that I need for it to race it but before I do I would like to buy the hop up parts for it before I race it.
losi09 is offline
