Losi xxx-4
Old 06-27-2006, 07:36 PM
  #991
Hmm, my battery bar has the humps on one side, and then a little tab mounted one cell in from the end for mounting flat packs or stick packs in place. Just make sure you use some thick tape, like insulation tape, on the flat side to mash the battereis down into the chassis, or else they can slide around. And the little ridges where teh holes are on teh bottom of tha chassis should pose no problem with mounting a pack, the tighter the fit the less play in the pack, might be a little tougher to put the clips in, but better that than the pack coming out.
Rod
gatermaxx is offline
Old 06-27-2006, 11:19 PM
  #992
HVAC25000's Avatar
Trader Rating: 19 (100%+)
I meant keep track conditions in mind when picking a car. If all he does is run on a really rough, ungroomed track, he would be a lot happier with a xx-4 instead of the xxx-4, I think. I know I am, as are my 2 friends.
HVAC25000 is offline
Old 06-28-2006, 05:08 AM
  #993
jaejw1's Avatar
Default FAQ SHEET
is there a faq sheet available for this buggy,, i just got a hold of one for really cheap and im putting it together,, i dont think it is the graphite version but im hoping to make use of what i have until i get the money to piece it into a x5,,,.. i wish i had time to read all the pages,, but with my wife staring at me constantly patting her feet on the floor wondering why i dont pay attention to her,EVERYTIME I GET ON THE COMPUTER, im unable to spend the time it would take to read everything...
jaejw1 is offline
Old 06-28-2006, 11:51 AM
  #994
Thank you very much guys for your answers and ideas... it seems that to mount the Team Orion Li-po 4800 will not be a problem at all
I've got two XXX-4 G+ (second hand) on the way... well, a lot of fun to come I guess
Cheers.
Blin is offline
Old 06-28-2006, 03:25 PM
  #995
www.teamlosi.com under product manuals. you can download everything.
HTHT
Rod
Old 07-01-2006, 12:20 PM
  #996
Default Gear ratio
Hi guys,
The first of my two second hand losi xxx-4 g+ arrived yesterday. It is in very good shape.
Here is my question : I plan to run a 3 stars Nosram/LRP brushless motor with the standard spur gear (92 teeth). Wich motor pinion must I use ?
Thanks for answering me.
Cheers.
Blin is offline
Old 07-01-2006, 04:21 PM
  #997
hey guys. i was wondering how the gtb 6.5 would be against a 11x2 d-6
my track is like 150 feet on the straight and im wondering if the 6.5 would out preform my 11 turn or if the 5.5 would be a better choice in my xxx-4
xxx-tkid is offline
Old 07-03-2006, 11:51 PM
  #998
My buddy has a 6.5, and I have a 9x2, and they are pretty close, the 11x2 is about the smallest mod motor you would want in that thing. We have not really compared lap times, with each driving our own, thant the other persons, due to driver skill and such, but I would say they are comparable (9x2 v 6.5). The 6.5 is about perfect for the XXX4, so I would say that might be a better motor then your 11x2.
HTH
Rod
Old 07-04-2006, 01:27 AM
  #999
Originally Posted by Blin
Hi guys,
I would like to purchase one Losi XXX-4 G+ very soon. But before, I have two questions that I would like to be answered.
1. Is the Losi XXX-4 G+ still a competitive car ? Does it have important flaws ?
2. Does the Team Orion 4800 Li-po fit in the XXX-4 G+. I'm gonna buy this battery for my sedans and I would like to know if it will fit my XXX-4 G+. Is there many modifications to do ? Any pics ?
Cheers.
The important flaw with the XXX-4 is that it is fragile. If you buy this car stock up on front end pieces. It used to be the arms broke a lot, now that they fixed that problem, it is everything else. Mainly hub carriers, and hubs
Matthew Bailey is offline
Old 07-04-2006, 02:00 AM
  #1000
Message to Matthew Bailey
Thanks for the answer...
But it seems that nobody runs the Losi XXX-4 with Lipo... I would like to know the exact modifications to do (if there are some modifications to do).
Thanks.
Cheers.
Blin is offline
Old 07-04-2006, 10:58 AM
  #1001
I wouldn't say that the xxx4 is fragile, it has it's moments of fragility, but you have to be haulin, or else hit teh arms just right. About everyone that I know that races teh XXX4 runs the plastic chassis cause it is more flexible and half the cost to replace
HTH
ROd
Old 07-04-2006, 05:01 PM
  #1002
yeah it breaks some times, but what car doesn't when you have a 10x2, or lower in it! This car is designed for one thing to race on a real track. I love my car, it seems that every forum I go in (RCCA) someone is talking about breaking their car. So do I personally think the XXX-4 G+ is fragile... nope.
just my .02
Jay
P.S. this is my first post here
pyro18t is offline
Old 07-04-2006, 06:43 PM
  #1003
macnkitty2002's Avatar
Happy July 4th everybody!
macnkitty2002 is offline
Old 07-04-2006, 07:00 PM
  #1004
Trader Rating: 29 (97%+)
When you run into a wall going 55 m.p.h. it is a good day if you only broke an arm.
party_wagon is offline
Old 07-04-2006, 08:14 PM
  #1005
I have had a XXX-4 almost since they first came out. As my title name states I have bashed it up pretty hard. The original front arms that came out with the vehicle were weak. Since then Losi has replaced them with different types that are a lot stronger. Can you break the vehicle YES can you break all the other vehicles YES. My point is learn the points on each vehicle and have fun. The only upgrades I did was replace all the pivot blocks and ends. Also changed the towers to graphite and doubled them.
I use a lipo battery in it. To make it fit right I did have to dremel the chassis where the tabs stuck up for the original battery and use double sided tape to the battery bar flipped over. It has never fallen out yet.
Basher is offline
