Losi xxx-4
Old 04-23-2006, 08:53 PM
  #931
beyondthepack's Avatar
sorry if this has been asked previously, but is there anywhere, whare I might be able to get red aluminum parts for the buggy? I have the battery strape (IRS), and screws, already.
beyondthepack is offline
Old 04-26-2006, 09:36 AM
  #932
Could someone give me advise for a grass setup?
blazeblazucki is offline
Old 05-07-2006, 06:04 AM
  #933
Taffyjnr5's Avatar
Trader Rating: 32 (100%+)
Default Losi JRXS Offroad Hybrid
Guys,
I have a spare JRXS and would like to convert it to offroad like the one Losi used at the worlds has anyone done this or does anyone know what parts were used to convert it. Thanks
Taffyjnr5
Taffyjnr5 is offline
Old 05-07-2006, 09:37 AM
  #934
they custom machined a lot of parts. you wont be able to do it unless you own a machine shop
Chris Jarosz is offline
Old 05-10-2006, 12:42 AM
  #935
I searched though this thread and did not find what I was looking for. On my XXX4, it seems that occasionally when I jump, or take a semi hard front end hit, not everytime or even close to everytime, the left front hinge pin pops out of the rear segment of the pivot blocks. This has only been doing this since I broke my front diff in a wicked flight into a piece of 3/4" plywood at full speed. I have the plastic braces, would running aluminum help? Aluminum for front and back of the front? or just the rear? It is really annoying, always seems to do it in a qual or a main, never in practice.
TIA
Rod
gatermaxx is offline
Old 05-10-2006, 07:45 AM
  #936
check to make sure the diff case isnt cracked. if it is it will flex causing the pin to pop out
Old 05-10-2006, 07:48 AM
  #937
Trader Rating: 42 (100%+)
TIA
Rod
The top (or lower) screws that hold the front diff case I bet are loose and/or stripped.
Nexus is offline
Old 05-11-2006, 02:04 PM
  #938
I had similar problem but with rear pins. I changed all pivot blocks and problem seemed to be gone. but in last main of Polish Nats I lost rear arm again it didn't broke etc but simply the pin slipped. After some practice runs I found out that the problem was in rear diffcover, i installed (during some routine cleaning) wrong , too short screws and pulled out those treads, this caused to much flex. It was really annoying as I was loosing races without any mistakes.
I think that the problem is not in std parts, aluminium blocks wont help, the are more resistant for all impacts but you will probably brake arm , which is simply saing more expensive that blocks.
Old 05-14-2006, 09:17 PM
  #939
SMcpot's Avatar
Trader Rating: 22 (100%+)
Trinity made a slew of red aluminum parts for the XXX4, but I think they've been discontinued.
SMcpot is offline
Old 05-18-2006, 06:56 PM
  #940
jimlazaro's Avatar
Hello fellow racer I need help what size of pinion gear I need,and here's what I have:
94 SPUR GEAR WITH NOVAK GTB 5.5 BRUSHLESS.
PLS. HELP....
jimlazaro is offline
Old 05-20-2006, 01:39 AM
  #941
jimlazaro's Avatar
So nobody run the xxx-4 with Novak GTB 5.5 now,Pls. need help.......
Old 05-20-2006, 07:30 AM
  #942
gear it at about 16 then try it. if it gets too hot go to a 15
Old 05-21-2006, 09:29 PM
  #943
HVAC25000's Avatar
Trader Rating: 19 (100%+)
What aftermarket parts are available for the XXX-4 now? Aluminum, carbon, bodies, etc.
Thanks!
Chris
HVAC25000 is offline
Old 05-24-2006, 09:46 AM
  #944
Suspended
RaceAce701's Avatar
Trader Rating: 87 (99%+)
does anyone know the final drive ration of the xxx4 compared to the xx4?
RaceAce701 is offline
Old 05-24-2006, 04:14 PM
  #945
Thanks!
Chris
trinity used to make lots of parts for it. a company makes alu. spindles but i dunno their web adress. its somewhere in this thread
