Losi xxx-4
Old 11-20-2005, 08:25 PM
  #736
Registered User
losirunner's Avatar
i found a guy who can do aluminum steering knuckles... if anyone interested....
losirunner is offline
Old 11-20-2005, 08:53 PM
  #737
Rysuleod's Avatar
http://www.amainraceway.com/content/specsamr01.asp
I emailed these knuckleheads and they never replied. No idea if they are in stock or ever will be again. $40 a pair. Ooofa!
Rysuleod is offline
Old 11-20-2005, 09:10 PM
  #738
Registered User
losirunner's Avatar
not those... i am talking aobut the things with the bearings in em... those are the hub carriers... not the sttering knucles. Thanks anyway!
Old 11-21-2005, 04:42 AM
  #739
Element's Avatar
I'm new to the X4 (bought mine a week ago yesturday) but if it uses xxx-s Knuckles these
should work.
Element is offline
Old 11-21-2005, 05:14 AM
  #740
csdspeed's Avatar
Default XXX-4 motor
Hey guys, can you suggest what motor should I use for my XXX-4? I'm currently using a 14x2 mod motor. Yes, it's fast but it drains my battery like peanuts. . I just want a high-torque mod motor that's fast but doesn't drain my battery quickly.
csdspeed is offline
Old 11-21-2005, 07:17 AM
  #741
losixxx's Avatar
should work.
there way different!
losixxx is offline
Old 11-21-2005, 07:25 AM
  #742
Registered User
losirunner's Avatar
get new batts.... i have a 10 double in mine and get close to 12 minutes run time with my 33's and 38's....
Old 11-21-2005, 11:06 AM
  #743
Default 3700 not fitting in the xxx-4
Has any one tried using the new batteries in the XXX-4. I can't seem to make it fit right. I tried dremaling out the battery brace. But when I do that it does not seem to hold the battery in tight enough. The batteries either fall out or it actually breaks apart inside the car. But when I put the 3300 packs in I do not have a problem.
hacker1 is offline
Old 11-21-2005, 12:38 PM
  #744
Registered User
losirunner's Avatar
I run the 38's just fine. The only thing i did was loosen the screws to the hold down posts two full threads. Also, make sure you built your packs straight, as that can lead to problems too.
Old 11-22-2005, 08:17 AM
  #745
DUB_Ben's Avatar
Anyone have a pair of DELRIN ARMS i could buy? Or a working link to buy them from somewhere????
DUB_Ben is offline
Old 11-22-2005, 12:17 PM
  #746
Registered User
losirunner's Avatar
I will look around for ya for some....
Old 11-26-2005, 12:28 AM
  #747
DUB_Ben's Avatar
thanks...
DUB_Ben is offline
Old 11-26-2005, 11:27 PM
  #748
csdspeed's Avatar
Default xxx-4 shock towers
Hey, can I use double shock towers for the front and rear? Some of my friends said that you could use double graphite shock towers to increase durability although they didn't say it's applicable in the XXX-4. Is it advisable?
csdspeed is offline
Old 11-27-2005, 11:50 AM
  #749
Scottmisfits's Avatar
You just need to use screws that are a few mm longer. You really only need the front from what I have found but you can do them both.
Scottmisfits is offline
Old 11-27-2005, 01:26 PM
  #750
Registered User
losirunner's Avatar
yup, run two fronts, and make sure u take out the retaining nut on the shock mounting screw in order to retain geometry.....
