Losi xxx-4
Old 11-11-2005, 12:00 PM
  #721
Registered User
losirunner's Avatar
i would buy yourself a nice servo right off the bat... atleast something medium high speed, medium high torque. Or else you will be looking to replace right away. I learned the hard way
losirunner is offline
Old 11-11-2005, 05:55 PM
  #722
W.E.D.Jim's Avatar
Trader Rating: 17 (95%+)
csdspeed, it wil work the steering and allow you to drive the car. The only draw back is you'll be needing to begin turning before you reach the turn, since the servo will be sloooooooooow and weeeeeeeak.
But it will work, especially if you aren't used to better servos.....yet.....Jim
W.E.D.Jim is offline
Old 11-11-2005, 07:21 PM
  #723
putok's Avatar
Trader Rating: 18 (100%+)
hi guys, have anyone tried to use a novak brushless gtb w/ 6.5 velociti motor to your xxx4g+. Can u help me with the spur / pinion setup. We run here in Phils. small to medium size technical track. Loose to hard pack track.tnx.
angel
putok is offline
Old 11-12-2005, 03:59 PM
  #724
tony montana's Avatar
Trader Rating: 76 (100%+)
hey guys I have a regualr xxx4 and and noticed on the g+ edition the rear shocks are reversed compared to my regualr xxx4. Can I reverse mine like the G+ with out any extra parts?
tony montana is offline
Old 11-13-2005, 08:39 PM
  #725
Trader Rating: 39 (100%+)
any one got a good set up for a indoor black dirt/clay mix. this track has tons of traction.
lmk thanks
Zac R is offline
Old 11-13-2005, 10:28 PM
  #726
Registered User
losirunner's Avatar
stock setup... works great... i ight try moving the front shocks out on the arm, and add a one way if it is high speed.
Old 11-16-2005, 12:46 PM
  #727
Registered User
losirunner's Avatar
Black or yellow belt... i have both... which one...
Old 11-16-2005, 01:57 PM
  #728
yellow for off-road chassis and black for sedan chassis
DAVE BERNATH is offline
Old 11-16-2005, 05:52 PM
  #729
Registered User
losirunner's Avatar
anyone got any aluminum hinge pin mounts they can sell me?
Old 11-18-2005, 12:35 PM
  #730
Registered User
losirunner's Avatar
up up up up
Old 11-19-2005, 02:54 PM
  #731
DUB_Ben's Avatar
What gearing should i use for a chameleon 19 by 1 in my XXX-4? I need tooth numbers, it has a blue spur on it right now...
DUB_Ben is offline
Old 11-19-2005, 05:55 PM
  #732
Team Duratrax's Avatar
Usually you gear the same as a stock motor, but I would start at 25/92.
Team Duratrax is offline
Old 11-20-2005, 11:43 AM
  #733
Registered User
losirunner's Avatar
anyone know who makes aluminum steering knuckles for the XXX4.... i broke 3 right hand ones yesterday, and at 7 bux a pop, they are kinda pricey...
Old 11-20-2005, 12:58 PM
  #734
DUB_Ben's Avatar
I need a set of delrin front arms... I geared it 23/92 for now.
DUB_Ben is offline
Old 11-20-2005, 07:04 PM
  #735
I am also looking for some delrin arms. Anybody have a source?
Jeff P. is offline
