Losi xxx-4
Old 10-04-2005, 01:02 PM
  #706
knucklebusta's Avatar
Well, I did follow the instructions. It basically says tighten it till you can spin one outdrive and the other one spins in the opposite direction, but when you hold both firmly, the pulley wont move. Correct?
I don't race. How often do you suspect I'll have to redo the diffs? What extra parts should I order for these? Ball bearings, pulleys, what else?
Thanks, Kevin
knucklebusta is offline
Old 10-04-2005, 05:00 PM
  #707
thedudeaturdoor's Avatar
a little of topic...
well what servos do u guys run?
and should i get the xxx-4 or the G+
ty matt
thedudeaturdoor is offline
Old 10-04-2005, 05:26 PM
  #708
Scottmisfits's Avatar
Get a XXX4 G+ if you get one. You get most of the parts you're going to end up getting anyway. The only upgrade I've done to mine is the aluminum pivot blocks.
Scottmisfits is offline
Old 10-04-2005, 07:10 PM
  #709
Hey, are there any good online stores for ordering parts for this buggy? My LHS is about 1.5 hours away.
Kevin
Old 10-05-2005, 04:42 AM
  #710
Lightbulb Servo and some other stuff
what type of servo are you guys running
im gettn at G+ soon but i dont know what type to servo to get
also is anyone running a novak SS5800 in there car?
what parts do u break so i know what for "santa" to get me
(i.e strip you slipper break a belt etc...)
what pinion and slipper do u use
Old 10-05-2005, 06:52 AM
  #711
W.E.D.Jim's Avatar
Trader Rating: 17 (95%+)
I would say redo the diffs once they feel very gritty, or once every 25-30 battery packs of runtime. This is conservative and assuming the slipper is correct, etc. Hardcore racers will redo the diffs every decent size race weekend (regionals, and higher level). Maybe every 10-12 runs!
Fro steering servo, I like the Air 357, or Jr has some good servos, with the 590 mg being the least expensive that will work well.
Superior Hobbies carries A ton of Losi stuff, 407-834-9299 Florida.
For parts i'd keep some ballcups on hand, front spindles and castor blocks(comes as a set), maybe a front tower and wing mounts if your really hard on the car, jumping big stuff, etc.......Jim
W.E.D.Jim is offline
Old 10-05-2005, 05:17 PM
  #712
Talking Bodies
i cant seem to find any bodies for the car!!
help plz
and will a Proline 1/8th scale wing fit on the back?
(cause im sick like that )
Old 10-06-2005, 05:42 AM
  #713
W.E.D.Jim's Avatar
The only bodoies available for the XXX4 are on the TeamLosi website, there are two types.
An 1/8th scale wing will fit with some "creative" engineering, but it will also make the car very tail heavy and hurt handling. Judgement call..............Jim
Old 11-08-2005, 06:02 PM
  #714
DUB_Ben's Avatar
Hey guys, im buyin one of these and I want a motor. What gearing do u recommend for a Team Orion Element SV2 19 turn? thanks.
DUB_Ben is offline
Old 11-08-2005, 07:03 PM
  #715
Registered User
losirunner's Avatar
runnin a 19T uh... stick with stock motor gearing... then work your way down.
Ok, i need a nice XXX4 painted body...
losirunner is offline
Old 11-08-2005, 09:00 PM
  #716
Registered User
losirunner's Avatar
anyone try putting the BK2 rear arms and hubs on there XXX4? Notice a difference? Trying to decide if i should... thanks!
Old 11-09-2005, 05:29 AM
  #717
W.E.D.Jim's Avatar
I like the BK2, VLA option on tracks were the one way works for more side bite in the long arm setting.........But there isn't a night and day difference, just an improvement.
...Jim
Old 11-09-2005, 08:33 AM
  #718
Registered User
losirunner's Avatar
Now, what stock motor seems to run the best in the X4 G+? I have a one way and diff option, and the track is high traction, tight and technical... North Mo Raceway, site of the ROAR Region 8's
Old 11-11-2005, 08:42 AM
  #719
csdspeed's Avatar
Default Servo
Is it okay to use standard servos on the g+? I don't have any more high-speed or high-torque servos for it.
csdspeed is offline
Old 11-11-2005, 09:16 AM
  #720
As long as it's standard size it'll be fine. Then it's just a matter of how happy you'll be with it.
