Losi xxx-4
Old 02-20-2005, 03:55 PM
  #616
HVAC25000's Avatar
Trader Rating: 19 (100%+)
Default Speed Controllers
Since the car is not in my hands yet, I can't examine the mechanics of the drive train. Is it possible for this car to go in reverse? I haven't purchased my speed controller yet, and before I go and buy one with reverse, I thought I should find out if belt drives can handle that.
HVAC25000 is offline
Old 02-20-2005, 04:56 PM
  #617
DEH
Yep...does reverse just fine.
DEH is offline
Old 02-25-2005, 03:02 PM
  #618
hey HVAC25000 try stormerhobbies.com. I know they are like the only online place that carries losi stuff.
minijosh is offline
Old 02-28-2005, 12:59 AM
  #619
HVAC25000's Avatar
Default Shocks
Anyone know where I can get threaded shock bodies? I tried Ebay already.
Thanks!
Old 02-28-2005, 02:55 AM
  #620
The slipper on my xxx4 seems to tighten up whilst I run it, I can even see the nut turning when I test it, has anyone experienced this as well? any possible fixes?
goodez is offline
Old 02-28-2005, 12:13 PM
  #621
INFERN0's Avatar
I have seen this before, all I can suggest is loctite on the threads to keep it from easily moving.
INFERN0 is offline
Old 02-28-2005, 12:17 PM
  #622
HVAC25000's Avatar
What kind of nut do you have? If it's a regular nut, then replace it with a locking nut. If it's a locking nut, replace it with a new locking nut (the plastic inside them wears out after a while). Here's a picture of locking nuts (not sure if this is the size you need or not) http://www.horizonhobby.com/Shop/ByC...rodID=LOSA6302
Old 02-28-2005, 12:22 PM
  #623
INFERN0's Avatar
Hmm that nut may be a tad small.............
The slipper on the XXX4 and G+ are very large and thin. They have no room on the nut for nylon so thread lock is the only option.
INFERN0 is offline
Old 02-28-2005, 03:08 PM
  #624
ADZY's Avatar
Originally posted by Doughty
forgot to add... a picture of my steering mods
Have you got any side view photos of this mod? If so could you please post them.
Thanks heaps,
Adam
ADZY is offline
Old 03-01-2005, 01:43 AM
  #625
thanks for the replies, Ill give the loctite a go
goodez is offline
Old 03-01-2005, 11:03 AM
  #626
DEH
Be careful. Use blue locitite and use a small amount. I tried this recently and used a small amount of blue. It worked, but when I tried to tighten it up a little, I couldn't. I had to remove the entire slipper assembly and use vise grips to hold the slipper while I used a crescent wrench to turn the nut. I think I used a little too much blue. I'd just weep it into a couple of threads.
D
DEH is offline
Old 03-01-2005, 03:11 PM
  #627
HVAC25000's Avatar
Default Nose
Well I finally recieved my XXX-4!
I love it, except for one problem. Every jump the blasted thing goes over, it comes in nose first and flips. Anywhere from 5mph to full speed, it still does it. I've tried hitting the jumps at full speed, tried accelerating up the jump, and tried letting off the throttle and then punching it a few inches before the lip (which would, on previous cars I've owned, pull the nose up and keep the car level in the air).
The car balances at about the leading edge of the motor, which is actually behind the midpoint of the car, which to me means it should either fly level, or land on the rear wheels (again, that's how all my previous cars have behaved).
These same jumps work for my 2wd buggy, my 2wd truck, my 1/8 buggy, and even my bike.
All I can guess is it has something to do with the suspension. The front shocks are stiffer than the rear ones, can this cause the problem? It has pink springs in the rear, and blue in the front.
Any suggestions?
Thanks!
Old 03-01-2005, 05:55 PM
  #628
ADZY's Avatar
If the front is down whilst in the air try hitting the gas to bring the nose up, and if the nose is up try hitting the brakes whilst in the air, but as far as setup i don't know as i am only a new owner as well.
ADZY is offline
Old 03-01-2005, 07:24 PM
  #629
HVAC25000's Avatar
Ok, and if I'm already hitting the jump at full throttle, where do I get this extra "gas" to hit and bring the front end up?
Old 03-01-2005, 07:32 PM
  #630
ADZY's Avatar
Well if you are hitting the jump flat out, just hold the gas on when in the air and that will still have the same effect, but not as much if you were hitting the jump say half throttle, but i don't race on tracks were you need to hit jumps flat out to make them, so all you are relying on there is for the suspension to do all the work and if your setup isn't right it will always kick the back up, but i try not to hit the jump flat out, and as you are going up the face of the jump then accelerate, but do this up the whole face of the jump not just the last half.
ADZY is offline
